boost vs. n/a
boost vs. n/a
soon ill have my z6 head on my d15 block, now heres wats puzzling me, ahould i go boost or just get performance internals....... i dont want to go boost cause of the hassle and the cost of it, im more intresting in going n/a and see how much i ccan build up a sohc vtec for an everysay driver..... which internals should i change wen doing the head swap and how much would it run me ?
RE: boost vs. n/a
Cam, valve springs and valve spring retainers.
Building a NA SOHCreally depends on how much you want to spend, but if you want more than 150whp, I suggest boosting it. Check out that thread "Builing a powerful NA z6/y8."
RE: boost vs. n/a
+1
Avoiding boost cause of cost?? I don't think so, reaching big goals N/A is going to end up costing you more in the long run, and you'll run into just as many problems as you would if you go boost. It's a pretty common misconception that its "easier" to go N/A
RE: boost vs. n/a
boost does seem more complicated because of all the tuning and stuff, but in all honesty i think itd be worth it. And with a complte valvetrain kit, cam, forged pistons, rods, retains and hte likes, that will cost you as much if not more than Pete's Turbo Grocery List. If you boost it with the new VTEC head on there, you wont regret it
RE: boost vs. n/a
Don't forget about the added weight of boosting, and the lack of traction a fwd setup has with the big torque of a turbo. N/A isn't out of the question.
I, however, agree that boosting is the way to go for power.
RE: boost vs. n/a
ORIGINAL: pWnEdU
and also theres only so much power you can make with N/A, where as with a turbo you can keep upping the boost (althoguh you're probably going to have to rebuild internally eventually anyway). You could always bore that thing out though.
RE: boost vs. n/a
I don't see how you couldn't have heard about traction problems. The FWD setup has the worst traction of any drive setup, and the addition of torque only amplifies it. Google the effects of weight transfer, that should shed some light.
RE: boost vs. n/a
Dude, what are you talking about?Are you really suggesting thathe shouldn't boost because he is gonna have traction problems? And that staying NA will alleviate this problem?Damn, I better go rip my turbo out before I spin the wheels.
