building an all motor b16a2
Old 01-22-2007, 09:40 PM
Sleepin95CivicDX's Avatar
Default building an all motor b16a2
hey guys. im looking to build my b16a to run high 13's, all motor. so far my mods list is:
B16A2 /w 99-00 SI tranny
Stage 2 Clutch
Lightened Fidanza Flywheel (not quite sure of the weight)
Custom Cold Air Intake
Custom 2.5" Catback exhaust /w Hi Flo cat and straight thru Magnaflow muffler
4-2-1 Edelbrock Header
Good amount of weight reduction inside
A/C removed
next i'm looking to go with a Edelbrock Performer X intake manifold with a 65 mm throttle body and Integra type r cams, advancing the timing just a bit.
After that, what do you recommend I do? My goal is to be able to run a 13.9 at least. Thanks!
Old 01-22-2007, 09:43 PM
ef4life's Avatar
Default RE: building an all motor b16a2
high compression pistons, ctr cams, ported and polished head, fully balenced bottom end, better valvetrain asembly, a good tune
Old 01-22-2007, 09:57 PM
what compression do you recommend? 11.0:1? 12.2:0? higher than that?
Old 01-23-2007, 12:21 AM
Kedawei's Avatar
Already stated my opinion in another thread, but I'll state it again.
B18 swap. LS/vtec would be great if you're on a budget. It looks like you're going to have to break into this motor anyway. Why not just build a LS block on the side while you drive this one around, and when you're ready slap your B16 head on there. B16 heads are great. With good cams, higher compression and a tune, you could make 200 to the wheels easily.
A good piston to use in this set up would be OEM B16 pistons, bored .020" over. You can order these from any Honda dealer/website. They'll cost you like $40 each, and yield a static compression of 12:1-12.7:1 depending on the thickness of your headgasket used. With a good tune you could run it on pump gas.
Cams would be key. You'd want itr/ctr cams at least. Although (normally I don't endorse this brand)Skunk 2 stage 2 cams seem to give great results.
Some samples of similar builds:
http://forums.evans-tuning.com/viewtopic.php?t=3894
http://forums.evans-tuning.com/viewtopic.php?t=3030
http://forums.evans-tuning.com/viewtopic.php?t=2957
http://forums.evans-tuning.com/viewtopic.php?t=1491
http://forums.evans-tuning.com/viewtopic.php?t=2340
http://forums.evans-tuning.com/viewtopic.php?t=3090
(I didn't search too far, those are on like the first two pages of that section.)
If you can afford it, or were planning on getting forged internals anyway to save rotating weight. You might try a B20 block. It has a 3mm wider bore, so you need aftermarket pistons to reach high compression. No OEM option will do. However, that bore will yield more power.
ferocios31
10-31-2011 05:56 AM
Captain_Sl0w
10-04-2008 03:05 AM
civic_driver_389
EK Swaps
13
10-24-2007 05:55 AM
thakid
12-09-2006 02:25 PM
CivicTurk
02-07-2006 10:08 AM
Quick Reply: building an all motor b16a2
