burn!
Old 07-11-2005, 04:37 PM
raceminus's Avatar
Default burn!
i just recently bought my electron blue pearl 99 si .. it just started to heat up while idling. when i first got it .. the temperature was always consistently cool while idling for 5-10 minutes .. but now after a few minutes the temp starts to rise .. i replaced the coolant and it still heats up .. can anyone help me out ..?? .. thanks
Old 07-11-2005, 04:44 PM
Street Sniper's Avatar
Default RE: burn!
90% probability of needing a new thermostat. Maybe a new water pump. How many miles?
Old 07-11-2005, 05:49 PM
LEVIII's Avatar
Default RE: burn!
does it overheat when you drive?
Nice ride BTW
Old 07-12-2005, 12:22 AM
sacicons's Avatar
Default RE: burn!
and does it leak anything? or does antifreeze magically disappear?
Old 07-12-2005, 01:33 AM
Default RE: burn!
What is the temp where you live?
What is your coolant mixture percentage?
Are you banging the AC full blast?
Driving in stop and go traffic nonstop?
Need a bit more info please.
Old 07-12-2005, 01:21 PM
2000Ex's Avatar
Default RE: burn!
I've noticed that my temp guage kinda jumps every once and a while but I think it is related to a loose belt.
Old 07-31-2005, 10:19 AM
Default RE: burn!
first step is check for coolant leaks. second is replace the themostat. if it still overheats check to see if it overheats when the ac is on. check to see if you fan is running. if you fan doesn't run at all most likely that is your problem. if your fan works when ac is on but when you have it off and it is running hot and the fan doesn't come on something is wrong with your fan circuit. too many variables. if you would like help figuring it out contack me somehow.
Old 07-31-2005, 10:35 AM
LEVIII's Avatar
Default RE: burn!
I dont think he means it is over heating, just heating up quicker
Old 08-01-2005, 06:01 PM
Default RE: burn!
yeah i'm confused... is it overheating or heating up quicker?
Old 07-27-2008, 07:25 PM
Default RE: burn!
I just bought an '01 Si and I have the same trouble. If I take it through Timmy's drive through all of a sudden the temperature starts going really high and I have to turn the heat on and then it doesn't cool down again for hours. It doesn't overheat, the temperature just gets really high.
If I just drive, and don't drive slowly, stop-and-go, or idle, then it's fine.
I replaced the rad, coolant fan, and thermostat but still have the same problem. My mechanic is mystefied.
Quick Reply: burn!
