A/C stoped working
Old 08-15-2010, 01:07 AM
lxcivic's Avatar
Default A/C stoped working
It seems like my 97 Civic lx is just keep faling apart. Couple weeks ago my AC stoped working it turns on but it doesn't blow cold air, and for some reasone A/C pipes High presure very hot you cant touch that hot and the low presure is on the hot side too, i don't remember which one of them but one of them should be ICE cold and it isn't. Any ideas????
Second problem happend today, my odometer stoped working, speed gauge works but my miles don't turn over anymore. what could be wrong here?
Please help me out, im trying to sell it.
Old 08-15-2010, 04:55 AM
KingDakota12's Avatar
Well the AC could possibly have a leak like mine used to. Go out to your local Autozone by some refrigerant with sealant in it or buy the sealant separate and put it through the low pressure valve works perfectly.
Old 08-15-2010, 05:03 AM
link32183's Avatar
make sure you buy the gauge that goes with it so you dont overfill it that can be bad, no idea about odometer problem
Old 08-15-2010, 10:56 PM
90 Civic's Avatar
The problem with putting in stop leaks into the A/C is if that doesn't fix it & you have to take it to a shop they will refuse to work on it. The stop leaks plug up their recovery machines & they have sniffers to detect it.
Old 08-16-2010, 08:59 AM
Big Mick's Avatar
true best is to see if you have a leak or not. If you have enough freon your problem might be electrical like probably a open in the low pressure switch or some thing similar. my 2 cents.
npaetsch
02-09-2010 04:24 PM
gunaa
10-22-2009 11:36 AM
chrisroug
10-02-2006 11:36 AM
ivanovmrp
01-03-2006 08:07 PM
lukbrw
06-09-2004 01:36 PM
Quick Reply: A/C stoped working
