Can I do the timing belt myself
Old 09-14-2005, 12:10 AM
bkhobbs's Avatar
Default Can I do the timing belt myself
I'm moderatly smart and extra poor, with a chilton and HCF's help could i (or should i) attempt to do a timing belt change? 98 civic ex coupe (manual) w/ nothing other than I/H/E. What do the pros think? What all would i need? Whats the chance that i'll complete F my baby up?
Old 09-14-2005, 07:11 AM
Default RE: Can I do the timing belt myself
From what i've heard it doesnt seem like that huge of job. I do however recommend you do your water pump at the same time though. I guess your best bet would be to read through your Chilton's and see if it "seems" too difficult for your personal skill level.
Old 09-14-2005, 11:38 AM
Kappa22's Avatar
You could do it, but you can't cut corners on the specific instructions. Some things in there are very sensitive...
Old 09-14-2005, 12:50 PM
Street Sniper's Avatar
It's not exactly child's play.
It costs that much at the shop for a reason.
Do you have an impact?
There are lots of great write ups on doing it. Read through one with pictures and see what you think.
Old 09-14-2005, 02:25 PM
As long as you have access to all the tools needed, you should be able to do it yourself.
If this is your first time trying mechanical repairs, I'd make sure I had a buddy with me, cause you always run into some problem that you may need a ride to the local parts store.
Old 09-14-2005, 02:43 PM
Yeah, go buy the longest damn breaker bar you can find. That crankshaft pulley bolt really pissed me off a lot when I did mine.
Old 09-14-2005, 02:58 PM
Kappa22's Avatar
ORIGINAL: Street Sniper
Actually, the majority of shops overcharge no matter what. And no, you don't need impact tools to do the job.
Old 09-14-2005, 08:26 PM
trickyvick's Avatar
My first experience at a timing belt change:
2 hours.....took basically everything off of the engine (power steering, a/c tensioner, motor mount, etc.)
Got it all back together and started it....ran perfectly.
I noticed that I had left out the belt guide (the one on the outside of the crank). I went back in to put it in and I broke the harmonic balancer
($40 part at the scrap yard......$130 at the dealer)
Pulled the part on Labor Day at the yard....had the Civic up and running by 11:00 a.m.
Other than that, it was a simple exchange and I learned from my mistakes.
I would like to add that I have done timing chains on several vehicles so I am not necessarily a novice.
Old 09-14-2005, 09:06 PM
sacicons's Avatar
but you will need a torque wrench. and like XCM said, a big *** breaker bar to get the crank pulley bolt loose if you dont have an impact. (yeah, I know Kappa, I know....)
Old 09-14-2005, 09:07 PM
I didnt say an impact was necessary, I just asked if he had one. Some impacts wont even get that bad boy off.
Quick Reply: Can I do the timing belt myself
