car starting help
Old 04-20-2010, 04:38 PM
1992 civic driver's Avatar
Arrow car starting help
when i let my car sit for a few days it has trouble starting but when it starts its fine runs very good.
Old 04-20-2010, 04:46 PM
jprommel's Avatar
Angry Admin
check the charge on your battery?
Old 04-20-2010, 06:46 PM
ok thanks for your help
Old 04-20-2010, 11:01 PM
Largen's Avatar
Ya... does the engine hesitate to turn over? like is it sluggish? if so then its your batt, run a Load Tester on it to see if its any good, if thats not the issue, what do you mean by it not liking to start? could you describe it?
Old 04-21-2010, 09:42 AM
i did not do anything yet but like when i turn the key it will crank and crank then it will start some times it will start fast and some times it wont and when its warmed up it starts fine. i dont run the car much. thanks for your help. everyone
Old 04-21-2010, 11:13 AM
Try priming the fuel system first by clicking the key on for 2 seconds then back off, repeat that two or three times, then finally turn it all the way to crank. If it starts easier then there is a check valve in the fuel pump to keep the gas from all running out of the lines when the car is parked for a while and sometimes it goes bad.
Old 04-22-2010, 07:15 PM
i was in my car today and i did what you said and it worked but this thing beeps 5 times then it stops after it stop i tried starting the car and it started right up i think its made to do that i dont now thanks for all your help everyone
jjnielsen82
08-31-2010 08:13 PM
n8te81
03-09-2008 04:45 PM
96civichb
06-06-2007 06:07 PM
totenkopf
05-31-2007 03:36 PM
fast93civic
08-22-2005 10:27 PM
Quick Reply: car starting help
