cell light
Old 02-01-2009, 11:09 AM
zilliboy's Avatar
Default cell light
hey i had a problem with my radiator and a got it fixed myself .
but now i got a check light on and i checked the way you guys do
and it blinked six times fast i checked and it was this one
6 ECT - water temperature sensor. does this has anyting to do with
the radiator problem?? do you need to fix it ,is it easy??? thanks ...
Old 02-01-2009, 11:42 AM
of course you do...
i hope you aren't one of those people who only fixes problems with their cars that keep them from working.
Old 02-01-2009, 01:02 PM
The ECT is a crucial sensor that tells the ECU what temperature the engine is. This is essential for the engine to run optimally. In a practical sense, you may see reduced gas mileage (engine will run rich) and possibly idle problems if this sensor is not working.
The ECT has two wires and is located beneath the distributor. It resides immediately next to the coolant temperature sending unit, which has only one wire. When installing the new ECT, be sure to coat the threads with high temperature liquid gasket.
Old 02-01-2009, 06:32 PM
zilliboy's Avatar
umm ok thanks. did that happened because of the overheating problem i had ,or
it could have hapened before that?.
Old 02-01-2009, 06:38 PM
You may never know. It just happened when you didn't expect, as do most car problems.
Ray012874
10-19-2005 10:26 AM
Remmy
10-12-2005 11:44 PM
Trader4Less
04-21-2005 06:17 PM
AgentofDarkness
03-31-2005 11:09 AM
Quick Reply: cell light
