Child lock - back driver's side door won't open
Old 09-01-2007, 03:00 PM
RogerBurks's Avatar
Default Child lock - back driver's side door won't open
I have a 1998 Honda Civic. One of my relatives accidentally engaged the child lock on the back driver's side door, and now it won't open.
Anyone had this happen, or know of a possible solution? Is there a way for me to disengage that child lock without taking it to a dealership?
Thanks in advance for your help.
Best,
Roger Burks
Old 09-01-2007, 04:06 PM
thisisoriginal's Avatar
Default RE: Child lock - back driver's side door won't open
Couldnt you just flip up the little child lock switch on the door? There should be one.
Old 09-01-2007, 04:53 PM
cyberx32's Avatar
Did you try opening the door from the outside? thats what the child safety lock does. it stops the door from opening from the inside.
Old 09-01-2007, 05:20 PM
ORIGINAL: cyberx32
No. His relative is still stuck in there. haha.
Old 09-01-2007, 06:46 PM
RogerBurks's Avatar
Clarification: it won't open from the outside or inside. It won't open at all. That's why I need help.
Thanks again.
Old 09-01-2007, 09:24 PM
cyberx32's Avatar
Maybe the locking mechanism fell off from inside the door. Try to take apart the handle from the inside and see if its still connected.
Old 09-02-2007, 04:39 AM
AOL.COM's Avatar
the only way to fix the lock is to get the door panel off , but , the door panel doesnt come off unless you open the door[:@], so you might have to destroy the door panel to get into the lock
Old 09-02-2007, 10:35 AM
gin0o0o's Avatar
Did you try unlocking the door first?
Old 09-02-2007, 08:31 PM
windcalmer's Avatar
All you need to do is call a locksmith that can come and jimmy the door open for you. Then you can pull the door panel off and fix whatever is broken. Most of the places the jimmy car doors are dirt cheap. Like $20 max. So just call on or if you have a slim jim then you can do it yourself.
Good luck.
Old 09-03-2007, 06:32 PM
cyberx32's Avatar
ean to pull the whole panel off. First try to remove the little plastic piece right where the handle is. It should be one screw, and look behind it to see if the metal hook is still attached to the door
mrossi22
02-05-2015 06:59 AM
mrossi22
02-04-2015 10:28 AM
Koala
10-12-2007 09:38 PM
griz
04-24-2007 08:05 AM
althius
05-20-2006 10:05 PM
Quick Reply: Child lock - back driver's side door won't open
