d15 and d16
Old 08-21-2008, 08:54 PM
Nightrider's Avatar
Default d15 and d16
I gotta a crx with a d15b6 and the its got rod knock, and click and clack so im wonderin if i just take out the motor itself and replace the motor with a d16, do i need to change the tranny or ecu or any types of conversion, or would it be just bolt and plug and play???
Old 08-22-2008, 11:21 AM
Is it really rod knock, or just the valves? Valve clearance must be adjusted manually to compensate for wear. If the valves are loose, the engine will make a clicking / rattling noise, especially when cold, it will almost sound like a diesel if it is bad enough.
Old 09-02-2008, 09:31 AM
c3o5nnect's Avatar
Right, definitely check your valves first... You don't want to replace the whole engine if you don't have to. Valve job much cheaper than a engine swap.
0slowpoke60
05-03-2008 04:08 PM
civicraider
02-08-2007 01:40 AM
birdmane
02-07-2007 07:42 PM
Lordnismo
11-26-2006 08:05 PM
kbeers
06-23-2006 11:56 PM
Quick Reply: d15 and d16
