Engine Codes
Old 04-05-2006, 07:24 PM
Fiirkan's Avatar
Default Engine Codes
i have noticed that there is not a post with engine codes, so courtacy of Sha_Zapple and General_Duce at my local community car forum we now have engine codes.
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp
D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130ps
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K20A3 2.0L DOHC i-VTEC '02+ RSX
/'02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S
02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps
F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp
F22A1: 1990-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 125 hp (93 kW) @ 5200 rpm, 137 lbf·ft (186 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22A4: 1990-1991 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5200 rpm, 142 lbf·ft (193 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22A6: 1990-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 140 hp (104 kW) @ 5600 rpm, 142 lbf·ft (193 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
All listed above are Single Overhead Camshaft [NON-VTEC] controlling intake and exhaust, for the most part having interchangeable parts
F22B1 1994- VTEC Accord, 2.2 liter (2156 cm³), MPFI fuel system, 145 hp (108 kW) @ 5500 rpm, 147 lbf·ft (199 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22B2 1994- Non-VTEC Lx, Dx Accord, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5300 rpm, 139 lbf·ft (188 N·m) @ 4200 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
It was suggested that F22B2 non-VTEC's were superior builds for turbos due to the fact that they had more low end torque curves and were easier to maintain and set up with valve adjustments required less frequently
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL 150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiR S Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps
C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp
C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP
C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp
J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
*JDM: Japanese domestic market (available in Japan)
*USDM: US domestic market (available in US)
*ULEV: Ultra Low Emissions Vehicle
Accord
5G Japan '94-'97 H22 2157 10.6:1 190hp@6800/152ft/lbs@5500
4G Japan '90-'93 F20A 1997 9.5:1 150hp@6100/137ft/lbs@5000
Civic
6G Japan '97-'00 B16B 1595 10.8:1 184hp@8200/118ft/lbs@7500
6G Japan '96-'00 B16A 1595 10.4:1 168hp@7800/118ft/lbs@4500
6G Europe '96-'00 B16A 1595 10.4:1 168hp@7800/118ft/lbs@4500
5G Japan '92-'95 B16A 1595 10.4:1 168hp@7800/118ftlbs@7300
4G Europe '89-'92 B16A1 1595 10.2:1 158hp@7600/111ft/lbs@7000
4G Japan '88-'91 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
4G Japan '89-'92 B16A 1595 10.2:1 158hp@7600/112ft/lbs@7000
4G Japan '90-'91 B16A1 1595 10.4:1 160hp@7600/111ft/lbs@7000
3G Japan '86-'87 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
Crx/Delsol
5G Europe '94-'97 B16A3 1595 10.2:1 158hp@7600/112ft/lbs@7000
5G Japan '92-'96 B16A 1595 10.4:1 168hp@7800
4G Japan '89-'92 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
3G Japan '85-'87 ZC 1595 9.6:1 129hp@6800/106ft/lbs@5700
Integra
3G Japan '95-'97 B18C 1797 10.6:1 178hp@7600/129ft/lbs@6200
3G Japan '95-'00 B18C 1797 11.0:1 197hp@8000/130ft/lbs@7500
2G Japan '90-'93 ZC 1590 9.0:1 119hp@6300/105ft/lbs@5500
2G Japan '90-'91 B16A 1595 10.4:1 158hp@7600/112ft/lbs@7000
1G Japan '86-'89 ZC 1590 9.6:1 129hp@6800/106ft/lbs@5700
Prelude
5G Japan '97+ H22A 2157 10.6:1 200hp@6800/161ft/lbs@5500
4G Japan '92-'96 F22 2156 160hp@5800/156ft/lbs@5000
4G Japan '92-'96 H22 2157 10.6:1 200hp@6800/161ft/lbs@5500
Old 04-05-2006, 07:25 PM
ef4life's Avatar
Default RE: Engine Codes
you posted a d15b as a non-vtec, when it actually is vtec in JDM form. the non vtec is a d15b2 88-91 and a d15b7 92-95. but other than that nice list
Old 04-05-2006, 07:36 PM
Fiirkan's Avatar
lol well like i said it was something that was on another forum, so i cannot take any credit for it there is 2 variation of it, i think bioth have imperfrections but with that many engines to type out i can't blame them
Here is the link to the page http://www.nbautotunerz.com/phpBB2/viewtopic.php?t=1789
Old 04-05-2006, 10:44 PM
Kedawei's Avatar
Old 04-06-2006, 01:27 PM
Kappa22's Avatar
ORIGINAL: ef4life
And the EF B1
polo708
01-08-2008 02:05 PM
chaseman1978
09-30-2006 03:29 AM
Punter
12-23-2005 06:09 PM
smokingemcee
12-04-2005 11:28 PM
Quick Reply: Engine Codes
