engine cooling question
what is the purpose of bleeding the coolant system, i know its suppose to get rid of the bubbles going through the coolant system, but where do these bubbles come from and what can they cause as far as engine temp?
RE: engine cooling question
The bubbles mostly are trapped air, causing an inability to completely refill everything with coolant after draining it for whatever reason. You don't want bubbles in your engine. A bubble will cause a hot spot, and that could lead to cracking the head or block.
cjcs71
07-07-2010 06:22 PM
cvandenb
02-22-2009 06:02 PM
