Engine Question
Old 03-08-2008, 07:06 AM
MicahCt's Avatar
Default Engine Question
**Please don't flame, this is a serious question, and i have taken the time to research what i am asking before i posted. **
Looking into a 97-99 Civic (Coupe) to buy since the Gasoline price is skyrocketing, but i still want to leave some doors open with the car. I researched your FAQ's and stickied threads and i couldn't get the answer i was looking for, so here goes;
In 97-99, Is there a DOHC VTEC engine that comes in a (2 Door) model of the Civic that isn't the Si?
D16Y8 Also available in New Zealand under the code D16Y6 Australian version D16Y4 [ul][*]Found in [ul][*]1997-1998 Honda Civic EX Sedan[*]1996-1998 Honda Civic EX Coupe[*]1996-2000 Honda Civic EK Sedan[*]1996-2000 Honda Civic EX (USDM)[*]1996-2000 Honda Civic SI (Canada Only)[*]1996-2000 Acura 1.6EL (Canada Only)[*]1996-1997 Honda del Sol Si [ul][*]Displacement: 1590 cm³[*]Bore and Stroke: 75 mm X 90 mm[*]Compression: 9.6:1[*]D16Y8 1.6 16V SOHC VTEC 2 PGM-FI 1590[*]127 hp@6600 rpm 108tq@5500 rpm[*]Head Code: P2J[*]Piston Code: P2P[*]Redline 7000 rpm[/ul] [/ul] [/ul]Sadly, Doesn't give whether it's DOHC VTEC or not And then...
D16Y7 VTEC <-- Yay!, But...DOHC?
[ul][*]Found in: [ul][*]1996-2000 Honda Civic DX/VP/LX/CX[*]1999 Honda Civic Special Edition - SE(Canada)[*]1996-97 Honda del Sol S [ul][*]Displacement: 1593 cm³[*]Bore and Stroke: 75 mm X 90 mm[*]Compression: 9.4:1[*]Power: 106hp @ 6400 rpm[*]Torque (ft·lbf@rpm): 103 @ 4,600 rpm[*]Valvetrain: SOHC 16 valves[*]Fuel Control: OBD2 MPFI[*]Head Code: P2F[*]Piston Code: P2E[/ul] [/ul] [/ul]In search of someone to set me straight! I hope you can see that i did indeed do the research before posting, like an idiot.
And by the way, First time poster here. Hi, I'm Micah.
Old 03-08-2008, 07:16 AM
Default RE: Engine Question
the D16Y8andD16Y7 areSOHC. Out of those two the only VTEC one is the D16Y8. All D-series engines are SOHC.
ORIGINAL: MicahCt
[ul][*]Found in
[ul][*]Displacement: 1590 cm³[*]Bore and Stroke: 75 mm X 90 mm[*]Compression: 9.6:1[*]D16Y8 1.6 16V SOHC VTEC 2 PGM-FI 1590[*]127 hp@6600 rpm 108tq@5500 rpm[*]Head Code: P2J[*]Piston Code: P2P[*]Redline 7000 rpm[/ul][/ul][/ul]
[ul][*]Found in:
[ul][*]Displacement: 1593 cm³[*]Bore and Stroke: 75 mm X 90 mm[*]Compression: 9.4:1[*]Power: 106hp @ 6400 rpm[*]Torque (ft·lbf@rpm): 103 @ 4,600 rpm[*]Valvetrain: SOHC 16 valves[*]Fuel Control: OBD2 MPFI[*]Head Code: P2F[*]Piston Code: P2E[/ul][/ul][/ul]
Old 03-08-2008, 07:31 AM
MicahCt's Avatar
A perfect response Overlooked those details, as i thought i did. Thank you for the information.
Old 03-08-2008, 10:05 AM
EJ8_Man's Avatar
Actually there are DOHC D-Family motors, but they're older designs from the mid 80s to mid 90s.
Here are some DOHC D series motors:
D16Z5
D16A1
D16A3
D16A8
D16A9
ZC
Old 03-08-2008, 10:19 AM
ORIGINAL: EJ8_Man
D16Z5
D16A1
D16A3
D16A8
D16A9
ZC
dang, i forgot about those. lol
Steve Court
11-21-2006 11:48 PM
soldout712
10-30-2006 10:13 PM
Xtreamist06
08-30-2006 09:14 PM
Benny Sim
07-19-2005 07:43 PM
Quick Reply: Engine Question
