getting the timing done, HP increase?
I don't know about Hondas, but from working with Miatas, if you temporarily bypass the ECU, then adjust the timing on the earlier OBD-1 cars from the stock 10* to 14*, it shifted the powerband enough to give more useable torque in lower rpms. At 18*, you'd gain a little bit of power, but you had to run premium fuel because of the knocking. At the most, the cars were gaining maybe 4 pounds of torque.
But as mk378 pointed out, make sure your timing is good to go, first. Then I'd check the play in your throttle cable. If there's excess slack, your throttle isn't opening to 100%, and your engine isn't making it's current potential anyway.
The best way is to have someone sit in the driver's seat and floor the gas pedal (engine NOT running, don't even give them the keys) while you check under the hood that the throttle plate has moved to wide open. You should not be able to move the lever on the throttle body any farther.
DeanHensler
01-04-2010 05:07 PM
reaper2022
12-14-2008 11:24 AM
