Having problems rolling up/down windows - HondaCivicForum.com
Reply
Old 03-17-2008, 05:38 PM
Default Having problems rolling up/down windows
I have a 2000 Civic EX 2D. The passenger side window will not roll down and the drivers side window seems to be slowing every time I roll it up or down. They both have electric motors. But is it the motors or regulators that need replacing? Or both? And is anyone reading this selling any or know anybody that is???
Old 03-17-2008, 07:24 PM
Default RE: Having problems rolling up/down windows
my drivers side window does not roll up and stay up. Once it reaches the top it falls back down 1/4". It's like something is loose so I have to carefully raise the window so it doesn't drop once it reaches the peak.
anyone know what my problem is, they're power windows.
Old 03-17-2008, 09:03 PM
cyberx32's Avatar
Passenger window the motor might be dead, and the driver side window it sounds like its dying. If the window falls off the track you will need to buy a regulator also.
Old 03-20-2008, 05:19 PM
Would'n it be good if Honda read these forums.
For the record, on power windows that get stuck and won't go up and down as the're meant too.
My 07 Civic 3,000 k's on the clock has a dodgey d/door window already.
(for the moment the addition of silicon spray in the baily channel is doing the job, however I am su****ious that the regulator mechanism is not rigid enough to keep the glass positioned!, so unless the glass is totally free to slide, it jambs).
Old 03-21-2008, 10:26 PM
I imagine that the gears that are pushed by the motor are slipping.
Old 03-25-2008, 07:27 PM
I had the same problems with my drivers side window on my Honda Accord Heres my solution,
Question- "Hey guys I need quick help. I curently have a 2 door 1994 honda accord sitting in my garage and the driver window dosent roll up or down, I still have power to it and you can still hear the noise of it attempting but, I dont think the wires are either pulling or the wire is caught up in the window somewhere. The window is a power window not manual and im sitting with the door off already trying to figure it out.
thanks ahead of time"
I later found out that this was the problem
"ok wellI believeI figured it out. After getting tired of the stupid thingI cut the wire to just take the whole motor out and replace it, I found that inside the part kinda by the tracks the ball that rolls the wire was broke in half. I dunno if you guys can picture that but I think thats it im going to go buy a new motor tommrow. "
Old 03-25-2008, 07:52 PM
cyberx32's Avatar
You didnt have to cut the cable, theres a simple plastic piece that can disconnect it. And are you talking about the regulator split in half? (the metal piece with the tracks?)
Old 03-26-2008, 07:51 AM
try checking all your fuses because i know there is a fuse for driver and passenger power windows
Old 03-26-2008, 07:57 AM
i have the same problem both window not workin properly i bring to window mechanic and said thats hondas all time weaknesses the window rolling problem but anywthey fix it and charge me 75 dollars for both window
Old 03-26-2008, 08:01 AM
My04Civic's Avatar
Administrator
keep windows up, dont fart
Reply
Thread Thread Starter Forum Replies Last Post
all windows except drivers will only go down but not up!!! billboboggems Mechanical Problems & Technical Chat 2 06-11-2011 10:17 AM
95 Honda Civic EX (horn not working, windows not going down all the way) Juans_MX3 Mechanical Problems & Technical Chat 3 04-07-2010 03:38 PM
Windows wont go down!! (HELP) ghosttech Mechanical Problems & Technical Chat 6 03-23-2009 07:23 AM
power windows dont go down d_reyes Mechanical Problems & Technical Chat 2 04-19-2008 10:23 PM
Car Slows Down When Coasting Down Hills? Esquirrel Mechanical Problems & Technical Chat 19 08-14-2005 11:16 AM
Tags
1994, civic, drivers, ef, fall, fix, honda, power, problems, properly, responding, rolling, side, stay, track, window, windows, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
