head fitement question.
Well my buddy just gave me a d16z6 motor with a blown lower end and I'm wanting to know if tje d16z6 head will work on a d16y7 block . I have a d15b7 head on it now and will I be able to reuse my intake manifold and related sensors and what computer would i need .
The motor is from a newer model. It's a d16y7 block with a d15b7 head and intake manifold.. the motor was on the car wen I got it. Everything works good I just want vtec. Will I still be able to use my intake from the d15b7 on the d16z6 and it work right. Wat about the wires for vtec to the p28 cuz I have a non vtec harness.
Oh, ok, that helps a lot to understand your question.
So I assume you've got a 1995 DX then?
The D15B7 intake manifold will be just fine to use, and you won't have to worry about the IACV I mentioned. The D16Z6 head will fit the D16Y7 block. You'll have to use a different timing belt though, and i'm not sure which one you need... probably the D16Z6 timing belt. To wire up VTEC, follow the instructions in this DIY. It's only 2 wires that you are adding. Very simple, just a little bit time consuming.
95lsvtec
02-14-2006 11:46 PM
