hel phelp help help help!!!! =(
#21
^^ Yep, a spun bearing will leave you with metal shards in the oil. You don't have to convert to a OBD1 engine harness if you go with a z6 block. You just wouldn't wire up the knock sensor, there are a few little things as well, but I couldn't tell you what since I don't have 1st hand experience. However, i was planning on doing something like that in the near future. And yes, the y8 can go on the z6 block.
J/w, are you able to put a z6 block in your car since you are in CA?
If you plan on keeping the car, good luck with the motor swap.
#23
I'm pretty sure the law in California is that the engine must be the same year/newer than the car it is going to be put in.
#24
You can use a newer engine than the car, or convert from OBDI to OBDII. But you can't go the other way. The engine and the control system can't be a type from a model year older than the car is.
That's because pollution standards have gotten tighter through the years and a car must continue to meet the standards applicable to its model year. It is not legal to modify a car in a way that would be expected to cause it to make more pollution (i.e. lower tech engine / controls). Technically this is true in all 50 states but California is really the only one that checks.
#25
Guest
Posts: n/a
ohh ok i understand now.
so if i were to do anything i would have to get a d16y8 engine either 1998 oor higher?
and what do i need excatly?
my friend was telling me since i dont here any knocking i might get away with changing just the rod bearing but if i drive it more i might ruin the crank shaft.. as of right now could i get away with just getting a brand new y8 bottom? or would it be better to change the whole engine
#26
well, the mettle shards will have traveled, chances are you toasted your crank, and maybe even your block, you CAN repair it though, by getting a line-bore done, but chances are it will be cheaper to get another engine, good luck though....
#28
Guest
Posts: n/a
damn guys this sucks..
so this guy on craiglist wants to trade?
my engine doesnt make any noises like knocking. and i had my step dad drive it today. ad he couldnt even tell. and he has tought me everythig i know about cars. i had to point out the noise to him. he things it the transmission cuz it only makes the noise while excellerating. and this guy on craiiglist has a 1994 or 5 acura integra ls just had an engine swap. it has a b20. my car has only bolt ons. and his car just has lowerd suspention...is it a good trade? should i trade? cuz i dont have enough money to pay for my problem. i love honda's but i used to drive a 1990 integra,,, till i through a rod causing a hole the size of my fist. due to...gues......low effing oil.. i need to change the way i drive. and this is an automatic. and i think that this will help me? what do you guys all think
#30
And I'm sure you drive a little more cautious then the OP.
No matter what it is, it can't be good that you have metal shards in your oil. So yes something is really wrong.
