Helpppppp =(
lol this is exactly what happened to my front shock after I lowered my car(took a few weeks of driving for the piston to bust out like that).
Don't worry though, it's an easy fix. As long as the piston isn't bent your shock is still good. Whoever put the strut together used the wrong washer. I had to take apart both front shocks to fix my problem(one piston already went through like your pic and my other shock was getting close to going through as well)
They probably used the thin stainless steel washers that were included in the kyb mount kit, but you're supposed to re-use the thick tapered washer that sits on the top of the piston, below the threaded part(where it forms a cone)
here's a pic of the shock upside down, but you can see the bronze looking washer that's needed.
http://pollito.no-ip.com/sleeper/Sus.../Front/010.JPG
btw you might want to check your hood for a lump, because when that happened I nearly put a hole in my hood.
Simply take apart the shock(you want to do this for both shocks in the front), replace the thin bent washer with the one in the pic. Fixed.
