Hi Beam question
Old 02-16-2006, 11:36 PM
Fiirkan's Avatar
Default Hi Beam question
is it possible to wire it so that my high beams, and low beams stay on at the same time, when i turn the high beams on?? cause if i can set that up i might just beable to use the money i am getting on performance parts instead of the projectors... if not then projectors it is[8D]
Old 02-17-2006, 12:58 AM
NTX's Avatar
NTX
NTX is offline
Default RE: Hi Beam question
you'd get stopped by the first cop to see you.
Old 02-17-2006, 01:53 AM
Location: new mexico, then mt, then alaska, now mt again...
yea, not to good of an idea, that would be so f'ing bright tho, lol... you could do it, but you would get pulled over!!!!! then be back at square one, and be out money if you got a ticket....
Old 02-17-2006, 06:02 PM
sickcivic07's Avatar
Member
Well if you wired it to where the highs and lows stayed on when you hit the highs and when you turned them off the lows would be on then you wouldn't get pulled over.
Old 02-17-2006, 06:03 PM
Member
Also,I have seen things on ebay that do that. At the moment I can't remember the name of them but they are out there.
Old 02-17-2006, 08:28 PM
mill$civic's Avatar
just get a wiring diagram of your headlights and play around with it, be careful tho
Old 02-17-2006, 08:29 PM
Fiirkan's Avatar
ORIGINAL: sickcivic07
sorry i didn't clerify that more.. what he said^^ is what i was talking about. to have both on when the highs are supposed to be on by themselves
Old 02-18-2006, 12:25 AM
ok, ok, i get it now, that would be sweet, go for it, find that diagram mill$civic was talkin about!!!
Old 02-18-2006, 08:01 PM
natecivic92's Avatar
Doesnt your bright already do that just cuts on the other filiment i might be wrong some cars have 2 lights.
Old 02-18-2006, 09:12 PM
Fiirkan's Avatar
yeah my car only has one bulb and it cuts from one sectyion of the filament to the otherbut if i hold the switch before it clicks they both come one and it is 3 times as bright as just the high beams.
Quick Reply: Hi Beam question
