hornn not workin
Old 11-27-2008, 11:36 AM
zilliboy's Avatar
Default hornn not workin
ok heres the deal my horn is not workin i had the srs on
but i turned off duing the jump thing i alread checked the fuse under the hood
does any1 knows how to fix it or wut could be i have a honda ex 98 thx
Old 11-27-2008, 11:49 AM
there's fuses under the dash too that relate to the horn i think
Old 11-28-2008, 03:30 AM
Having the SRS light on and having the horn not work seems to point to the cable reel under the airbag. Have you done any work under the steering column lately? If so, were all wires reconnected?
Old 11-28-2008, 02:06 PM
Yeah it really sounds like your cable reel is broken. This will also break the circuit to the driver's air bag, causing the SRS light to turn on. The cable reel must be installed properly or it will break the first time you turn the steering all the way to one side. Also if you disconnect the steering rack and turn the wheel, that will likely break it.
Old 11-28-2008, 02:39 PM
ej6buddy's Avatar
The rear brake light fuse and the horn fuse are linked, if you shorted the brake lights out somehow, then there's your problem. just check your brake light fuse under the dash.
Old 11-28-2008, 05:34 PM
zilliboy's Avatar
i bought the car like that wear can i find this cable wut it looks likes?? i think it may be it thx
Old 11-28-2008, 05:40 PM
When I bought my 2000 DX awhile back, mine came that way too. The previous owner had the rack and pinion replaced, and they didn't properly reinstall everything. So when the previous owner took his first right turn, the cable snapped. You have to get the part from the dealership or from a junk yard. To get to it, you have to pull all the covers off of the steering column, use a torx screwdriver to remove the airbag (after using the safety jumper on the underside of the airbag), probably the steering wheel too (I used a spark plug socket), and then the cable reel is under that. There are a couple of screws to remove it and a couple of connectors to pull off it.
To replace it, you manually turn the replacement reel all the way to one side, then spin it around 3 times to get it to the center. Your steering wheel is designed to spin around 3 times only in either direction, so if the reel was misaligned, a simple spin of the wheel ripped the cable. These instructions are on the reel itself too.
It looks like this:
1.6LNVTEC
12-18-2010 09:20 PM
civicvtec95
17
07-10-2010 03:50 PM
c4rtm4n
05-21-2010 04:25 AM
POLYTHING
03-23-2007 11:16 PM
01CivicEX
11-28-2005 06:16 PM
Quick Reply: hornn not workin
