headlight question
RE: headlight question
You should have something that needs to be turned (only about 1/4 turn) to line up to the 3 tabs on the outer edge of the headlight to pop it out. There is also an electrical connector that has a tab you need to press down on while pulling the wiring from the bulb.
I think that's a H4 type. Unplug the wire connector, pull the rubber piece completely off, and you should find a metal clip holding the bulb in by it's metal flange. Remove the clip and change the bulb,secure new bulb with clip, put rubber piece back on, and plug in the wire.
