I need help with my subs and amp
RE: I need help with my subs and amp
yea man if they were 105 for me id have 2 type r's with the 1200w alpine amp in my trunk but idk. do u think it would be ok to run my rockford 100w 2 channel amp to 2 alpine type r's? i will keep the p1's till i wanna spend the money for the type r's. unless i can find it cheap on ebay i will return my setup.
after you find out if your subs are even hooked up right then this is all you need to do and really what you need to do......
http://www.resnet.trinity.edu/areynol1/gain.htm
ORIGINAL: n8te81
ok if it is the one that i looked at, assuming it is based on the price, then it is powerful enough to run 2 type r's pretty well. it won't run them to full potential, but its still gonna be pretty loud.
the amp will run 250 rms per channel at 2 ohm, so running the dual voice coils(of the type r's)in parallel will allow for maximum power output of the amp.
also for the time being, it will output 125 rms per channel at 4 ohm per channel, and your subs handle 150 rms so its good for both sets of subs.
ORIGINAL: Sigracer10
A few rules of thumb here:
1. More speakers are blown with undersize amps than oversized ones.
2. Having the proper size box and correct tuning greatly affects the power handling. If the box is tuned improperly the speaker will have too much stroke and either blow or self-destruct. Run asin wavegenerator through your speakers, if you detect noticeable humps or dips, then it need retuning. Make sure the speaker is sealed and not leaking air anywhere but the vent, if it has one.
3. Cross out the speaker at the lowest possible frequency to minimise the power requirement. Try 70Hz or so. Go no higher than 100Hz. The higher you go the more power it takes.
4. Try to live with the lowest amount of "bump" you can handle. It will sound more natural and your speakers and amp will be happier. Your neighbors will appreciate it also. One of my pet peeves is listening to a trunk rattlingas a car passes with the sub onoverkill.
5. If the speaker sounds boomy, try adding some insulation inside.If it sounds dead, remove some. When it sounds crisp and tight, you probably got it right.
ORIGINAL: Gene J
