idle question
idle question
hmm ever since my car backfired using nitrous its been idling really high... any possible reasons for this??
it tries to idle normal when i first start it but after 2 secs its jumps and idles at 2k rpm's... anyone help???
thanks
thanks
RE: idle question
was runnin 91 octane fuel and its still in ther... dont really wanna drive it till i get it fixed seeing as from the high idlin it smells kinda bad when its stopped...
checked all the hoses and vacuums, but woldnt that make my idle go lower??
and if i blew the welds on the intakes would it just take re welding to fix it??
RE: idle question
Backfired?!
Probably fried the IAC, MAP, and TPS, or any combination there of.
I'd loosen your throttle cable, and try to lower your idle by repositioning it slightly. It's a ghetto fix, but it'll bring down your idle.
RE: idle question
ORIGINAL: augie
It was a joke man
With a loose hose or vac line your idle would surge, or go higher, not lower.
Are you losing any oil or coolant? Might be time for a compression/leakdown test
RE: idle question
lol anyway just got back from chicago...
so im gonna re check all my lines and hoses and all that, if i cant find anything im gonna go buy a compression tester and test that and if i dont find anything im gonna take it to the shop and see what they can do.... the car runs fine and all just when im stopped i smell alot of extra burned gas... thinking thats from the idling...
not losing any oil or coolant so ill see what happens
honvic
09-02-2011 09:49 PM
JBaris
11-22-2010 03:56 PM
