Intrument Cluster help
Old 10-14-2009, 11:53 PM
1995CivicEXBMF's Avatar
Thank you i have a layout but this one is more visible let me try the fuse but my fuse tester lighted good but let me switch out and try real fast
  #22
Old 10-15-2009, 12:01 AM
Sadly no i replaced fuse 19 and the red/blk wire still shows no current
  #23
Old 10-15-2009, 12:19 AM
danomatic93's Avatar
June 2010 ROTM
How are you testing current here?
Either way, I highly suggest purchasing a multimeter to test for voltage.
If fuse 19 is good, check that when the plugs are in and the parking lights are on that the stock cluster illuminates. The dash lights should also illuminate as they run on the same fuse.
If the dash lights illuminate but the cluster does not, that wire it broken somewhere.
But, I'm going to bed.
  #24
Old 10-15-2009, 12:53 AM
ok im using a volt meter with a light bulb at the end of a rod and the dash lights (gauge lights) come on when i turn the parking/headlights on only the tachometer doesnt work on the cluster when the engine is on.
  #25
Old 10-15-2009, 12:55 AM
Goodnight and thanks for the help you have givin me if you still have ideas also thanks
  #26
Old 10-15-2009, 03:13 AM
im just curious have you tried jumping 12v into the red wire you say is supposed to have it but dont, to see if your tach will work.
  #27
Old 10-15-2009, 05:04 AM
I have an even more obvious question, has the "speed glow" modification physically jammed the tach needle at zero?
The tachometer, speedometer, gas gauge, temperature gauge, and many of the warning lights (oil, battery, and I think "check engine") all operate from the same power source. If that power is lost none of the instruments will work. Note that the gas gauge will remember the reading from the last time it had power, so it may not be obvious that it's not working.
I really don't like jumping live wires to stuff, especially when it's bypassing fuses.
  #28
Old 10-15-2009, 09:31 AM
Its a lesson learned ill never do it again without researching fully but there are two sources (2 12V Wires) of power in Plug B and with the Volt Tester it has confirmed there is no moving current of power in that one wire. However everything in the cluster works besides the Tachometer I even Tested the Cluster because I have two Instrument Clusters for this car and my old clustr i know worked fully, which now everything but the Tachometer works.
  #29
Old 10-15-2009, 04:10 PM
supersize's Avatar
Sir Banned-a-lot
hah! told u to test it! see, if you woulda listened to the fat kid in the first place u woulda knew this ish 2 days ago hahahah!
sorry, its not usual that i am right so im taking it in stride hahahaha
  #30
Old 10-16-2009, 03:01 PM
NAH THAT WASNT THE PROBLEM sorry caps im too lazy to go back anyways no who ever had the car before me really messed it up so i went in and replaced some fuses and relined some wires now im good
Quick Reply: Intrument Cluster help
