Lights help
Lights help
Hello all--new here with a problem. Bought my daughter a Bull Dog Security remote start for Christmas. Has a 2002 civic. Son and I did the install. It works fine. But we now have no headlight, parking light, tailights or dash lights. Had to remove an aftermarket alarm system that had a wire going from it to a green plastic disconnected plug above the left vent. Checked headlight fuses, headlight relay under hood. Have no power to either side of the fuses. relay has B+ to 2 of the terminals and will light a test light dimly on the other terminal. When probing the terminal with the test light it will trun the headlights and parking lights on. If I also probe the wire at the green plug that the first alarm is hooked to it will also turn lights on. I am at a loss as to what the problem is. We didn't mess with anything inthat had to do with light I gues but something is wrong. Any ideas before I take it to Honda dealer. Thanks
RE: Lights help
1) Check whether fuse 2, 15, 17, or 19 in the under-hood fuse/relay box is blown (see picture for circuit diagram).
2) It doesn't make sense that the fuses don't have battery power. How are you doing the tests?
3) Based on your information, it sounds like one or more relays are bad.
4) Your test also suggests that the green plastic plug is hooked into the headlight/taillight circuit, but how this was done is unclear
RE: Lights help
Thanks for the response. All fuses in both the under hood and underdash fuse box are good. pulled and looked at and used a test light to verify. Headlight fuses will not light with a test light on either side of the fuse with or without light switch on. Can run 12v jumper wire to either fuse and will light the headlight. The green plastic plug is not hooked to anything but had a wire tapped into it that went to the alarm system relay that was in the car when she purchased it. My guess is that when it was set it would flash the lights when someone tried to break in--grounding that one wire turns on all the lights and headlight buzzer. One more thing---the flash to pass will turn the light on and the light on buzzer also. I work on ambulances with miles of wiring on them and this one is driving me crazy. Thansk again.
RE: Lights help
How it works is the light switch grounds the blue and red wire, which causes the relays to pull in and energize the 15A headlight fuses, then current flows from those fuses to the lights.
So assuming fuse 19 is good and energized (it should be live all the time) there is probably a break or something unplugged in the blue and red wire, or the light switch is bad or not grounded thru the black wire on terminal 12 (though if that were the case, the lights would not work because there is no path out of the high/low beam switch).
If you ground the blue and red wire the headlights should come on. And grounding the blue wire should turn on the taillights. I'd take the column cover off and do that right at the combination switch.
RE: Lights help
ORIGINAL: reborn55
1) Headlight fuses will not light with a test light on either side of the fuse with or without light switch on.
2) Can run 12v jumper wire to either fuse and will light the headlight.
3) The green plastic plug is not hooked to anything but had a wire tapped into it that went to the alarm system relay that was in the car when she purchased it. My guess is that when it was set it would flash the lights when someone tried to break in--grounding that one wire turns on all the lights and headlight buzzer. One more thing---the flash to pass will turn the light on and the light on buzzer also. I work on ambulances with miles of wiring on them and this one is driving me crazy. Thansk again.
2) I assume that when you did the 12V jumper wire test, the headlights turned ON only when the combination switch was switched to the headlights ON position. If so, the results of this test suggest that the combination switch is fine.
3) It's difficult for me to interpret this observation without knowing how the green plug is wired into the system.
RE: Lights help
ORIGINAL: Civic Si 00
Just curious...Do you want to ask him out ..lol
But yeah Ron is smart with all this diagrams he puts up on this threads
ORIGINAL: civic_burns_all
^good job ron.
btw how old are you man?
^good job ron.
lol i was curious, if he was some mechanic or not
