Limited to 3000 rpms when at operating temperature.
Old 03-14-2009, 06:34 AM
3000 rpms's Avatar
Default Limited to 3000 rpms when at operating temperature.
I have a 1995 honda civic when i start my car in the morning my car runs fine but when the engine gets to operating temperature or warmed up it redlines at 3000 rpms or it doesn't exceed 3000 rpms. can anyone help me?
Old 03-14-2009, 08:02 AM
xsteinbachx's Avatar
Well it's one way to save gas... You'll have to wait for Ronj to come on and tell you whats wrong or at least how to fix it. Also welcome to Honda Civic Forum since this is obviously you're first post and well... Im guessing you'll never post again by your account name.
Old 03-14-2009, 11:21 AM
3000 rpms's Avatar
I don't have problem posting to find out more about the honda civics cause i'm trying to get this one running to sell it and get another.
Old 03-14-2009, 12:02 PM
Is the CEL ON? Does the CEL work? Try retrieving CEL codes from the ECU as detailed at the link in my signature.
Old 03-14-2009, 02:32 PM
3000 rpms's Avatar
I've changed that out already but i'll try cleaning it next to see what happens after........... I will get my car tested tomorrow and we'll see what happens but cleaning that out will be the very next step.
Old 03-14-2009, 02:39 PM
CEL = check engine light
Click CEL link in my signature.
Old 03-14-2009, 03:02 PM
3000 rpms's Avatar
Only comes on when the engine gets to operating temperature, then the engine doesn't go above 3000 rpms.....
Old 03-14-2009, 03:04 PM
Retrieve the CEL codes from the ECU as detailed at the link in my signature. The codes will likely pinpoint the problem.
Old 03-14-2009, 03:20 PM
3000 rpms's Avatar
I'll check that tomorrow or monday when i get it tested to find out.... thanks for all your help today i will be on to let you what i got done. thank you
Old 03-15-2009, 08:47 AM
You are experiencing "limp home" mode. When the ECU has detected one of several possible problems, in addition to turning the CEL on, it will also impose a rpm limit.
You don't need any computer or special tools to read out the trouble code. Simply jumper the test connector with a piece of wire, turn the key on, and the CEL will blink out the code number(s).
Quick Reply: Limited to 3000 rpms when at operating temperature.
