Lx - ex?!
Lx - ex?!
I am debating whether to get an LX or EX. I had an 01 EX and was in love with the amazing mpg and reliability. I was looking on a few sites and seen that the LX gets better mpg than the EX? I thought they were the same engine except the EX has VTECH but I didnt think that VTECH would interfere with mpg unless "VTECH KICKED IN YO" haha. Is the EPA just compensating for when and if you get into vtech or does it actually bring the mpg down in general because the engine has it?
VTEC
If you have confirmed that the LX does not have a vtec motor, and the EX does, then they are not the exact same engine. Might be the same block, but not head. ECU would be different along with the fuel trims.
Wikipedia/reseraching can go far.
D17A1
Found in:
2001–2005 Honda Civic DX/LX/VP
Displacement : 1,668 cc (101.8 cu in)
Bore and Stroke : 75 mm × 94.4 mm (3.0 in × 3.72 in)
Compression : 9.5:1
Power : 115 hp (85.8 kW, 117 ps) at 6,100 rpm
Torque : 110 lb·ft (15.2 kg/m, 149 Nm) at 4,500 rpm
RPM redline: 6,750 rpm
Rev-limiter : 7,200 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : OBD-2 MPFI
D17A2
VTEC
Found in:
2001–2005 Honda Civic EX (US only) 2001–2005 Honda Civic LX (Europe)
2001–2005 Honda Civic Si (Canada only)
2001–2005 Acura 1.7 EL (Canada only)
2000–2007 Honda Stream 1.7 (Japan)
Displacement: 1,668 cc (101.8 cu in)
Bore and Stroke: 75 mm × 94.4 mm (3.0 in × 3.72 in)
Rod Length: 137 mm
Rod/Stroke: 1.48
Compression: 9.9:1
Power (North America): 127 hp (95 kW; 129 PS) at 6,300 rpm
Japan: 125 PS (92 kW; 123 hp) at 6,300 rpm[13]
Torque (North America): 114 lb·ft (15.8 kg/m, 154 Nm) at 4,800 rpm[14]
Japan: 154 N·m (114 lb·ft) at 4,800 rpm[13]
RPM redline: 6,800 rpm
Rev-limiter: 7,200 rpm
Valvetrain: SOHC VTEC, four valves per cylinder
VTEC Switchover: 4,500 rpm
Fuel Control: OBD-2 MPFI
D17A1
Found in:
Compression : 9.5:1
D17A2
VTEC
Found in:
Rod Length: 137 mm
Rod/Stroke: 1.48
Compression: 9.9:1
I think the EX has a different gear ratio which keeps the engine rpm higher for a given mph. This improves acceleration but decreases highway mpg. The difference is in the transmission, not the engine. VTEC and non-VTEC engines are basically identical in performance at normal cruising rpm.
VTEC
D17A1
Found in:
Compression : 9.5:1
D17A2
VTEC
Found in:
Rod Length: 137 mm
Rod/Stroke: 1.48
Compression: 9.9:1
D17A1
Found in:
Compression : 9.5:1
D17A2
VTEC
Found in:
Rod Length: 137 mm
Rod/Stroke: 1.48
Compression: 9.9:1
