Miles Per Gallon
Old 08-30-2010, 10:58 AM
imadvanced's Avatar
I double checked my temp gauge. It goes up to the bottom of that little thermometer picture, right below the wavy lines. I guess its closer to 1/3 of the way than 1/2 way up.
Old 08-31-2010, 06:08 AM
scrapn92lx's Avatar
Banned
ur good on temp bro
Old 09-01-2010, 03:45 PM
reznunt's Avatar
Make sure your tires are properly inflated. I went up 4 mpg just from filling mine up right.
I'm running 205/50/15 tires. That might be making my mileage off a little too.
x2. my truck got an extra 40 miles per tank when i added almost 10 psi.
Old 09-07-2010, 09:13 AM
beavisj's Avatar
This past weekend I have changed to 5W30 over 10W30 castrol edge syntec. Aired up tires to about 36 psi, still 28 mpg.
I was checking under hood & noticed in between the "V" of the exhaust manifold is a crack about 1/16" wide & approx 3-4" long. Will this cause mileage loss? I looked up on ebay a new catalytic & manifold just under $200
Old 09-08-2010, 07:12 PM
blueduns's Avatar
check the spark plug wires and anything else that could reduce the spark intensity.
BD
Old 09-09-2010, 03:48 AM
Cracked manifold is not good. Air coming through the crack fools the O2 sensor and makes the ECU run the engine rich.
Beware a lot of ebay "converters" don't actually have catalyst in them. They're just hollow shells.
Old 09-10-2010, 12:40 AM
beavisj's Avatar
@mk378 That may be my problem. On ebay I was looking at the whole manifold with cat converter on it. I know they have those so called "High flow cats" that are just a pipe. I was also looking online yesterday that permatex makes a super high temp putty for manifolds , I may look into that
http://cgi.ebay.com/ebaymotors/96-97...Q5fAccessories
Old 09-11-2010, 05:15 AM
imadvanced's Avatar
Yeah, I'm pretty sure your car has the one-piece cat-exhaust manifold system. I think all 6th gen non-vtec engines do. I tried a lot of different high temp putties when mine was cracked. they would stay on for a week at most, and then they would burn off. The price on that ebay manifold-cat is pretty good, but I couldn't tell if it came with a new gasket or any other hardware. Dorman makes a direct replacement that is carried by a lot of autoparts stores. The part number is 674-439.
Old 09-11-2010, 06:09 AM
Clean_Civic_98's Avatar
The exhaust manifold on my '98 DX auto had a crack in it a couple of years ago. I bought it about two weeks before the check engine light came on (which was for the crack in the manifold). I was getting 25MPG driving like an old lady! Put a new manifold in to the tune of $634, hopped on the highway a bit and was getting 38-40MPG. Now that I'm driving mostly in the city, I've been getting 31-33MPG, but I could be getting better if I wasn't so determined to hear the AEM SRI and the Flowmaster
So for sure get the manifold fixed.
Old 09-12-2010, 06:06 AM
beavisj's Avatar
Yea, it's a one piece system. the cats under the manifold. I will definitly get it fixed/changed. Thanks. I was giving up hope on what to fix, till I saw that
Quick Reply: Miles Per Gallon
