Mini me conversion
Old 11-03-2009, 04:20 PM
92civc4dr's Avatar
Default Mini me conversion
Is it worth putting money towards or will a motor swap be what you would lean to?
Old 11-03-2009, 04:25 PM
92civc4dr's Avatar
With d15 block and d16 vtec head.
Old 11-03-2009, 04:27 PM
yes its worth it, you will be happy,
Old 11-03-2009, 04:38 PM
rc2904's Avatar
Depends what your goal is for power. A minime is a great way to add power to a SOHC D series motor but if you have more money to spend you can get more gains with a DOHC motor like a B16(civic si) or B18(integra motor) or if you have even more money you could look into an H22 swap (prelude motor).
I personally would be interested in a minime or a b18 swap.
What is your overall goal and will you be getting a turbo eventually or leaving the car NA?
Old 11-04-2009, 04:39 PM
92civc4dr's Avatar
all motor.
Old 11-04-2009, 05:26 PM
PunisherInOKC's Avatar
How much power are you looking for? The D-series has a lower power peak than a B or H series. But the D series can make a good amount of power, and is cheaper to work on.
Old 11-05-2009, 11:08 PM
92civc4dr's Avatar
Im thinking b18. Is that a whole different set up?
Old 11-06-2009, 02:23 AM
how much $$$$$ do you have to spend? to put the B" series engine in your civic (if you do the work) will cost about $1000 to 1500, if a shop is gonna do it then it could be around $2000 to $2500,
now to give your little D" series a little more power you can put a vtec head on it, for about $300 (if you do the work) or around $500-$600 for a shop to do it.
Old 11-06-2009, 11:57 AM
92civc4dr's Avatar
i would be doing all the work.
Old 11-09-2009, 04:39 AM
xero_xero's Avatar
if you are comfortable with timing belts and head gaskets, make the d15 a DOHC. get a zc head out of an integra and go. your power capabilities will go through the roof atleast for the d series. otherwise, grab a b16 and tranny and swap the whole thing dont forget to wire for vtec....
khanselman
08-25-2006 12:40 PM
05CivicLX
06-29-2005 11:09 AM
redhonda69
06-23-2005 06:57 AM
GSXF
02-23-2005 09:45 PM
Quick Reply: Mini me conversion
