Is my engine Ok?
Is my engine Ok?
I checked my oil today, and the dip stick was bone dry This is after 3K while using Valvoline dino. I put one quart of dino in the engine and the dip stick read about half way in the safe zone. It seems to run fine. Do you think I'm OK as long as I keep the oil level up? How many quarts do you think she burnt (no visible leaks) in 3K miles? Why would I burn so much oil? I run 100 miles a day highway.
Can anyone recommend a new type of oil to try that will not burn as fast?
considering how much you run your civic, you should change your motor oil every 3k miles. i'd recommend switchin your motor oil to full synthetic motor oil if you haven't done so. and IMO i wouldn't recommend addin quart after quart of new oil when u need to with the already used oil in your motor.
Guest
Posts: n/a
yea! listen to them!! because i didnt check my oil once for 3 months and i blew my engine in my integra.
i didnt check my oil in 3 months in my last civic and i spun a rod bear, both are not fun to deel with,l and i check my oil every time i put gas in my car just to be safe
Use thicker oil...it takes longer to burn
I burn about 2.5 quarts a week in my car and I started putting either 10w40 or 20w50 in it and it doesnt but quite that much anymore
But Also I dont give a poop about my engine because of my new one.
Thanks everyone. I ended up adding two quarts last night and this put it back up to the fill hole on the stick. I might try Castrol GTX high milage and see how that works. The engine has seen Castrol GTX and as far as I know, it did not have any issues with it. I dont hear any knocking and I drove 50 miles this morning to work with out any issues, so I guess my motor is fine.
Does anyone think synthetic will not burn as much as dino? I do not want to keep adding expensive synthetic when I'm low.
soldout712
10-30-2006 10:13 PM
Xtreamist06
08-30-2006 09:14 PM
Legend1011
04-22-2006 02:30 AM
Benny Sim
07-19-2005 07:43 PM
