Need advice on replacing 95 Honda Civic LX engine
Old 12-07-2009, 08:43 AM
arguablybetter's Avatar
Default Need advice on replacing 95 Honda Civic LX engine
Hi all -
My recently purchased 95 honda civic lx has died. Apparently, the crank shaft fell off bottom of engine while running, consequently destroying at least bottom portion of engine.
i am trying to gain information on replacing entire engine, or at least bottom portion (head was just replaced along with valves). I am a newbie w/Honda's and not a car expert by any means.
If anyone has completed this job, please help me out with some info. I am trying to find out what my options are for engine replacement. Must new engine be from a 95 Honda Civic LX, or are there other models with same engine?
Thanks in advance for helping me out!
Scott
Old 12-07-2009, 01:26 PM
Stock replacement would be a D15B7 engine, found in all 1992-1995 Civic models except the EX and Si.
You can readily install just about any 1.5 or 1.6 liter D series SOHC engine, without needing to modify anything on the car. If you go to a VTEC engine, you will need to swap out the ECU and do a little wiring to make the VTEC feature work.
aundreas83
08-12-2011 10:59 AM
lostforawhile
16
05-26-2010 09:58 PM
piratefish
09-28-2009 09:17 AM
rgibbons
07-24-2008 09:41 AM
Quick Reply: Need advice on replacing 95 Honda Civic LX engine
