Need Help With d16y8 Swap Into 94 civic cx
i can sell you the harness but i would just be taking your money. cause your car is wired up for obd1 and the harness is obd2b. you dont need another harness all you need is to goto the local j/y and cut the vtec plugs from the harness and wire them into your p28 ecu when you get it. i explained previously what you need to do. i also have the vtec plugs listed on ebay for sale. its the vtec solenoid with the plugs to wire it in.
92-95 civic ex/si is what to look for you need the distributor and ecu. the plugs that u need look like this one hooks up to vtec and the other hooks upto the vtec oil pressure sensor. i have the plugs you need for sale right now on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
i got it boxed and is getting shipped today.
once you get a p28 ecu then you just ground the black wire. and the other 2 you run to the ecu.
ill throw in just for you the extra ecu pins needed to wire it into the ecu
I appreciate it man. You have been the only help Ive been able to get on this project, i know its hard putting up with my ignorance on the matter so i do appreciate all the help. Also, i have couple questions Ive been doing some Due diligence and read that the injectors wouldn't match up with my harness is their any truth in this if so what should i do? I also read on a write up that my cx distributor would work.. now i'm not sure how true that is but if its not the dz distrib will work for sure I only ask so i don't waste money of parts (which in the end if i didnt need id re sell so no big deal).
