NEED SWAP HELP ASAP
NEED SWAP HELP ASAP
i just bought a 94 gsr can i use that harness when i swap the motor into my 96 dx coupe or do i have to run the stock harness and modify it i have been told i can do ethier one but haven got a real answer if i have to run the stock harness what wires do i have to modify/change
RE: NEED SWAP HELP ASAP
harness....as in ECU harness? I'm thinking its OBD1, although the same GSR's were ran between 94-01 (B18c1) so i'm unsure, but if its OBD1 you need a covnersion harness and the new ECU.
travis, from what i know you should be able to pull of the d series harness if your using all new b series parts. call nix to get the correct answer, he should know. but if not, someone on here should know.
civicguy2488
01-22-2011 06:27 PM
rzerob
28
07-25-2007 01:54 PM
