Netami
Netami
ever heard of this company?
I bought a Quick Starter Switch Kit from PepBoys I know its used as a starter instead of using a key but its possible to use it as a security measure to have to hold it while turning the key to start right? Also its 12 Volts that wont hurt my battery will it? meaning drain the power fast
Here is a picture
Here is a picture
You can use it as an extra step to start your car. You could have it setup so you have to have your key in, then hit the switch then push the button. But in all honesty, take it back. You don't want something that huge as a security measure.
What you can do is use a small toggle switch in a hidden place. Or, even better is use something that people cannot tell is a toggle switch. I believe Addicted2Bass wrote a writeup about this. A quick search should find it. I would do it for you, but I am headed to bed sir. If you cannot find it, I will post a link to it when I get back on.
I like the idea of a extra feature to start your car. My buddys eclipse has a push start under the steering column somewhere. you have to put they key to ACC then push it. if you turn the key to start it does nothing. I think thats a pretty sweet idea,
amendolaro
02-07-2007 12:37 AM
