No sound from stereo
It tells the amps when to turn on just like when you stick the key in the ignition it turns the radio on that way the amps are on only when the radio is on and its not allways blue %99 of the time it is but it should say sumthin like rem, remote or amp turn on if its not.
I didn't think that would work...
like mk378 said...
"Also if you have a short in any one of the speaker wires, most aftermarket stereos will shut down their amplifier completely. None of the speakers will play."
So did you check for shorts or no? Because I bet that's probably the problem.
like mk378 said...
What color wire from your Civic does this blue wire ultimately connect to (see circuit diagram in my previous post)?
the harness he bought is one of those universal adapter harnesses made for a certain range of years of hondas, and his car doesn't have the amps that the remote wire would normally hook up to. so really it's just a dead wire hanging there in case he installed it on a car that had a factory amp.
Civic Si 00
02-26-2008 06:22 PM
cinefyl
05-21-2006 12:54 PM
