Old engine in new Honda Civic?
Old 01-04-2011, 04:29 AM
elman's Avatar
Default Old engine in new Honda Civic?
I was just reviewing the post to identify my engine type so I went and looked into the place where the engine type and number should be. I found it and it was: D17Z4 5000237. It also says VTEC on the engine and VTEC and VTI on the rear bumper. I came back to search and see what type of engine I have and it seems this type is pretty old and could not find any other information on it. There were few posts saying something about supercharged engine but apparently this is very old type.
But my civic is 2004 model. I am confused now.
Can somebody explain me please what the situation is here?
Old 01-04-2011, 05:25 AM
I've never heard of a D17z4. There is a D15z4 that's found in 96-00 Civics outside of the USA though.
The D17 engines were only really found in 2001-2005 Civics. Your engine is likely the correct one for the car.
Old 01-04-2011, 10:04 AM
these are the d17 engines that come in the 01-05 civics, ive done alot of research and i assume you are in the middle east. there isnt any info about the d17z4 but that its the 01-05 vti civic from the middle east. and the redline is 6800 rpms
D17 Series Engines (1.7 Liters)
  • Found in:
    • D17A 2001-2005 (Japan) honda civic
      • Displacement : 1,668 cc (101.8 cu in)
      • Bore and Stroke: 75 × 94.4 mm (3.0 × 3.72 in)
      • Valvetrain : SOHC VTEC (4 valves per cylinder)
      • Power : [lean burn] 115 hp (85.8 kW, 117 ps) @ ? rpm; 130 hp (96.9 kW, 132 ps) @ ? rpm
      • Torque : ? ft·lbf (? kg/m, ? Nm) @ ? rpm
[edit] D17A1
  • Found in:
    • 2001-2005 Honda Civic DX/LX/VP
      • Bore and Stroke : 75 × 94.4 mm (3.0 × 3.72 in)
      • Compression : 9.5:1
      • Power : 115 hp (85.8 kW, 117 ps) @ 6100 rpm
      • Torque : 110 ft·lbf (15.2 kg/m, 149 Nm) @ 4500 rpm
      • RPM redline: 6750 rpm
      • Rev-limiter : 7200 rpm
      • Valvetrain : SOHC (4 valves per cylinder)
      • Fuel Control : OBD-2 MPFI
[edit] D17A2
  • VTEC
  • Found in:
    • 2001-2005 Honda Civic EX (US only)
    • 2001-2005 Honda Civic LX (Europe)
    • 2001-2005 Honda Civic Si (Canada only)
    • 2001-2005 Acura 1.7 EL (Canada only)
    • 2000-2007 Honda Stream 1.7 (Japan)
      • Bore and Stroke : 74.98 × 94.4 mm (2.952 × 3.72 in)
      • Rod Length : 137 mm
      • Rod/Stroke : 1.48
      • Compression : 9.9:1
      • Power : 127 hp (94.7 kW, 132 ps) @ 6300 rpm
      • Torque : 114 ft·lbf (114 ft·lbf USDM[3]) (15.8 kg/m, 155 Nm) @ 4800 rpm
      • RPM redline: 6800 rpm
      • VTEC Switchover : 4500 rpm
[edit] D17A6
  • VTEC-E
  • Found in:
    • 2001-2005 Honda Civic HX
      • Power : 117 hp (93.2 kW, 127 ps) @ 6100 rpm[4]
      • Torque : 111 ft·lbf (15.3 kg/m, 150 Nm) @ 4500 rpm
      • Valvetrain : SOHC VTEC-E Lean Burn (4 valves per cylinder)
      • VTEC Switchover : 2300
[edit] D17A7
  • Found in:
    • 2001-2005 Honda Civic GX
    • Fuel CNG (Compressed Natural Gas)
      • Compression : 12.5:1
      • Power : 100 hp (74.6 kW, 101 ps) @ 6100 rpm
      • Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 4000 rpm
      • Valvetrain : SOHC (? valves per cylinder)
Old 01-04-2011, 11:00 AM
elman's Avatar
Yes I am outside US - in Azerbaijan. I am the second owner and this car has been ordered in 2005 through the dealer here. Quite possible that we were getting middle east models exported here. It also seems to be Asian model as most of Asian models have VTi on the rear.
Anything about HP of this engine?
Old 01-04-2011, 11:09 AM
i believe around 127 hp
ernie22golf
06-23-2010 11:03 AM
cannonierd
05-04-2007 12:57 PM
Elverdad1979
11-07-2006 04:35 PM
Elverdad1979
11-07-2006 04:34 PM
em1
10-16-2005 11:43 PM
Quick Reply: Old engine in new Honda Civic?
