Overdrive???
Old 04-19-2009, 05:39 PM
Originally Posted by PunisherInOKC
I'm confused here. You mention a overdrive button, then say its a 5speed. The overdrive button is only for automatics.
So, if its a stick - no overdrive button. And as the former owner of a 99Si, I know that you should be getting pretty good gas mileage being in 5th gear. Just make sure you keep her under 3,000 RPM whilst on the city streets.
He never said "button". 5th gear is an overdrive gear on the vast majority of transmissions. If the gear ratio for a given gear is less than 1:1 (ie, the Si's 0.875:1 5th gear ratio), that gear is considered an overdrive.
And fun fact of the day #342: The K20a/a2 uses a 6-speed transmission with a double-overdrive. The ratios for 5th and 6th gear in those transmissions are both overdrives.
  #22
Old 04-19-2009, 06:11 PM
PunisherInOKC's Avatar
Originally Posted by Jimbo&2000SI
Hey guys I have a 2000 Si and was wondering if I have an overdrive ---- button ----- or something to make rpm's drop when Im cruising at highway speeds. I thought 5th gear was overdrive but when Im in 5th gear doin about 70mph Im at 4000rpm's. This has to do with the way the gears are ratioed right?
He DID say button..
I win.
You lose
I'm the greatest..
I shall bow now.
* bows *
Please, hold your applause. =P
  #23
Old 04-19-2009, 06:19 PM
reading > me... stupid ADD lol
Either way, with a 5-speed, you still (usually) have an overdrive gear... just not a button
All an overdrive button on an automatic is is an overdrive selector... it's the same idea as putting it into D... all it does is tell the transmission what gears it's allowed to go into; select OD and it can select whatever gear it wants to, provided the rpm's are high enough to go into a particular gear.
  #24
Old 04-19-2009, 06:33 PM
Indeed. Thats why the button thing confused me. My 05 dodge has a 5th and 6th gear OD just like your random fun fact of the day #342.
  #25
Old 04-20-2009, 01:59 AM
CanSICoupe's Avatar
yea should i be using d3 or d4 driving around the city? is there an overdrive on this car?
thanks
Driving around the city I found that it really didn't matter. You might have a little bit more kick in D3, for the city, but you'll use a little more gas too because of the higher rpm. I always drove in D4, no issues, no slugging.
  #26
Old 04-20-2009, 08:21 AM
d3 & d4 won't be any different in the city; all d4 does is let the transmission go into 4th gear. I don't know what the minimum speed to get into 4th would be, but I'd imagine you won't be seeing those kinds of speeds in a city.
  #27
Old 04-22-2009, 12:04 PM
Jimbo&2000SI's Avatar
Yeah sorry about the whole button thing; It's just that I've never been in a car that does 70mph in 5th gear as high as 4000rpms. I didn't really think there would be anything to make the rpms drop but I was just wondering.
tmont2
12-07-2009 03:08 AM
brinriha
01-03-2008 01:28 PM
FocusBoy949
07-30-2006 02:55 PM
AgentofDarkness
07-06-2005 03:51 PM
spevie
05-27-2005 08:34 AM
Quick Reply: Overdrive???
