please help!
#22
Guest
Posts: n/a
yea, it does shake when i start driving then it goes away. i have felt along the tire i dont feel anything abnormal.
every wear i take it they say its my tires
they said my alignment being so messed up caused the bad tires,
they said its not camber they said the wear is from my tow being so bad.
they said its so bad on the right side because of how my alignment lines up.
when i get new tires on sunday or monday i will then get a camber kit, then get it aligned.
and if it needs new tie rods they will let me know
#23
I told you it was your toe. =P
Why do you want a camber kit? Waste of money really. You would have to have significant camber issues to really need a camber kit. The camber will not really effect your tires until way later in their life.
#24
I used to believe this whole "you need a camber kit" thing was a myth, but it really isn't.
I can only imagine how much camber he has, because according to his pictures, his car is hella low.
#25
Guest
Posts: n/a
yea its really low, i mean onces i have all of the tires off i will take pictures of them for every one.
when you look from the back of my car you can see the tires actualy cambering. if that makes sense, its extremly low do you think i should raise it? i mean the back coil overs or bottomed out and i have about an inch in the front left. what should i do??
i have 900 to spend..
new tires are gonna be about 400 for cheep ones
the alignment will be 50
and idk anything about camber kits, i mean i want one for the long run of my car,
if i were to have been in this possition a few months ago i would have sold the car for at least what i bought it for and then used that 900 to buy a better car,
but i like this one and i want to keep it.
i dont want to spend a lot well becuase i dont have much to work with but
how much does an alright camber kit cost?i know people who rock the ebay kits. i know people say stay away from ebay. but what should i do. realisticly with what i have to spend?
#26
I would go Buddy Club in the front (has stronger metal and is the lowest profile one, which is a big deal since you are so low... it will still probably hit the top of the strut towers though over bumps but it will still allow you to have it lower than other kits would). It's $150, which is not bad for a name brand front camber kit. Plus, it's Buddy Club so you can expect really nice quality.
Then for the rear you can either do the washer trick (you add washers between the stock rear camber arm things and the chassis until the desired alignment is reached), or you can get a rear camber kit. Best deal on the rear is the Blox camber kit at ~$80.
And yea, I would raise the car until there is little to no rubbing or bottoming out.
#27
Guest
Posts: n/a
new tires $408
life time alignment $145
buddy club front camber kit $180
trying to chase a kid who hit my girlfriends at her soccer game, after every thing was finished with on my car.... and breaking my hand...priceless =(
at least its alot easirre to steer, it doesnt shake,
but god damn is it hard to drive with a broken left hand
