power band!?
power band!?
hey am running a stock 89 civic si and i was wondering if anyone knew where the power band is? i shift around 5200 rpm and it seams like it has more power after that.
about when do u shift??
thxs
-brandon
thxs
-brandon
RE: power band!?
Max HP at 5600RPM
Max TQ at 3800RPM
amazing what searching wikipedia will tell you
D16A6
Also known as D16Z2.
Found in:
1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
1990-1991 Honda Civic EX Sedan
1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
1989-1996 Rover 216/416 GSi (UK/Europe)
Displacement : 1590 cm³
Bore and Stroke : 75 mm X 90 mm
Compression : 9.1:1
Power : 115 hp (86 kW) @ 5600 rpm & 100 ft·lbf @ 3,800 rpm, redline 7200 rpm (USA)
Note: 1988 engines were 105 hp (78 kW), MY89-91 hp was increased to 108
Valvetrain : SOHC
Fuel Control : OBD-0 four-point PGM-FI
Head Code : PM3
Piston Code : PM6
Max TQ at 3800RPM
D16A6
Found in:
Compression : 9.1:1
Valvetrain : SOHC
Head Code : PM3
Piston Code : PM6
