Power steering lines
Go to hondaautomotiveparts dot com select 95 EX, PS Pipe, and there is a drawing showing the approximate placement of parts on the car. The heavy hose goes from the pump to the rack. Everything else is on the return side. It comes back from the rack through one of the twin pipes all the way to the U-shaped pipe, which is mounted behind the grille to serve as a fluid cooler. Then out of the U pipe and into the other twin pipe, leading into the side of the reservoir. The bottom of the reservoir connects to the inlet of the pump.
Also note there's a little green sensor on the high pressure line. It was only used to boost the idle a little if the driver turns the wheel hard to the lock (such as when parking the car). It should go to ground pin B8 on the ECU. But I think it will work fine if you don't hook it up to anything.
norbster86
02-11-2010 04:52 AM
jpnolan
04-14-2009 11:11 AM
prodigyskate5
01-21-2009 01:13 PM
