Power Window issues
Power Window issues
For some odd reason the passenger side windows stopped working...I took out the driverside window operator and cleaned off the contacts but still didnt get any results...is it the motors for the windows or theoperator on the drivers door????
RE: Power Window issues
Ya, I checked all the fuses and they are still good, I even replaced them with new ones just to make sure....Ya I am aware that each window has a individual motor....I just didnt know if there was a bad or corroaded connection....the thing is sometimes my window works from the drivers side and sometimes it doesnt....and sometimes it works from the passenger side and again sometimes it doesnt....could it possibly be a regulator going bad??
Take the cover off the passenger door. Measure at the motor if voltage reaches it when you press the switch, if yes it's a bad motor or the regulator is stuck, if not it's a bad switch, wiring, fuse, etc. but most likely the switch.
eisenberg
02-14-2010 07:14 PM
AGibney
12-29-2009 05:59 PM
