priming oil pump
priming oil pump
when trying to prime my oil pump on my freshly built h22, i hear a metal on metal grinding noise coming from the crank side. i am scared to keep turning it over cause the noise is freaking me out.
I put oil in the hex access hole until it was coming out. what else can i do to get pressure or atleast get enough oil to stop the grinding? The oil pump is brand new as is every internal peice of the motor.
the dizzy, ecu and back up fuse are all disconnected btw.
__________________
__________________
if you did the build properly with resemble lube you should not hear grinding. take the spark plugs out pull the fuel pump fuse or disconnect the fuel pump and and crank it till the oil light goes out. do that after the grinding stops.
oilltd
06-10-2008 04:06 PM
oilltd
South West
06-10-2008 03:07 PM
