problem
Old 04-05-2007, 01:31 AM
Rancidgore's Avatar
Default problem
My 96 ex is having some problems and i dont know whats going on. its a 5 speed, and when its in neutral after the car starts to warm up a bit the rpms jump and then drop back down to idle and keep going up and down and up and down. i also had a overheating problem but that was resolved with a new thermostat. if any of you know whats going on i would appreciate the advice. thanks.
Old 04-05-2007, 01:42 AM
Rancidgore's Avatar
Default RE: problem
wow i feel very stupid...i just found out my civic is an ex not a dx. i ran the vin and all along ive been thinking it was an ex...turns out to be a dx
Old 04-05-2007, 01:46 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: problem
Well, if you have a DX, then you can get a gauge cluster from an EX civic and I think it should swap perfectly. At least, that's the case with 92-95 civic DX's
Old 04-05-2007, 07:01 AM
mybrokenblinker's Avatar
Default RE: problem
Yup, just grab a 96-00 ex cluster and it will bolt right up, no wiring needed.
Old 04-05-2007, 08:11 AM
Default RE: problem
ORIGINAL: danomatic93
what does that have to do with his idle surge? Other than having a tach to see the actual numbers at which it surges, which doesn't really matter.
Rancidgore, CLICK HERE. Its a list of stuff to check when you have idle surge. Since you swapped out the thermostat, I'm guessing that you've introduced air into the coolant system, fairly common problem. Did you bleed the system after you refilled it? If not, do so. If the surge continues, check the things in the link above
Slammed98silvercoupe
14
12-19-2010 05:16 PM
djt
06-21-2008 07:48 AM
redlines4us
08-22-2006 05:49 AM
tanksOnFire
01-08-2005 03:38 PM
tanksOnFire
01-08-2005 03:38 PM
Quick Reply: problem
