rear dish brakes
rear dish brakes
i am woundering what rear end i need to make my 98 civic ex have rear dick instead of drum. i haate drum brakes, and i like the look of dick brakes. if anyone knows i need to know asap
[align=left] [/align]
RE: rear dish brakes
Proportioning Valve (4040) (reccommended)
Brake lines
E-brake cables
Trailing Arms
Useable trailing arm bushings
Misc bolts
Rotors
Calipers that aren't seized
Brake pads w/shims
lower control arms w/useable bushings (can reuse yours)
upper control arms w/useable bushings (can reuse yours)
Compensator arms w/usable bushing (can reuse yours)
Toe arms w/usable bushings (can reuse yours)
Master cylinder, 15/16 (reccommended)
Brake booster (reccommended)
good hub w/good wheel bearings and lug studs
working bleeders
Is this coming from a car with or without ABS?
Try to get most of the parts from a non-ABS car, but some parts won't matter.
Brake lines
E-brake cables
Trailing Arms
Misc bolts
Rotors
Brake pads w/shims
working bleeders
This is the thread of my recent drum-to-disc conversion...
https://www.hondacivicforum.com/m_498529/tm.htm
These are all links I found very useful...
http://www.automotiveforums.com/vbulletin/t525526.html
http://www.diynetwork.com/diy/ab_bra...275324,00.html
http://www.civicforums.com/forums/43...elled-out.html
http://www.hazone.com/hdiscswap.htm
http://hondacrx881.tripod.com/discbrakes.html
If you have ANY questions, post 'em here or on my thread, or PM me. Roto also knows a lot about the conversion.
DELANCER
02-02-2007 12:44 AM
