removing decals
RE: removing decals
GOO GONE.....
pull the stickers off as much as you can by using your fingernails, and after ya have most of it off use the GOO GONE stuff and a rag to wipe off the glue... just apply to the rag, let it kinda soak into the glue alittle and start rubbing..
RE: removing decals
o ya my bad... ya that works good to to remove the main sticker but i guess depends if its a decal/sticker or vinyl graphic, vinyl can be picked off preaty clean by just using your finger nail tho heat will help. but a cheap sticker will be a PITA with all the glue they use!
RE: removing decals
ORIGINAL: Peg_Leg
be carefull with goo gone it can take paint off try a hair dryer and wd-40 or pb blaster ive used them and had no problems just take your time
RE: removing decals
ORIGINAL: Peg_Leg
RE: removing decals
It's actually on the body
And it's reallllly hard to take off
I tried with just my fingernail and warmed it with hot water (probably didnt do much though) and it won't peel, kind of just curls up into micro-micro ***** of white plastic decal
ill try the blowdryer and see what removal products i got like that
RE: removing decals
shoot... theres this stuff my brother got to remove a "brake for motorcycles" sticker he had on his bumper. I'll go check see if I can find it. Came off nice and clean too would never know it was there.
