Replace the cluster?
RE: Replace the cluster?
Yup, simple swap, so long as it's from a 96-00.
Two screws for the bezel.
Four screws for the cluster.
Unplug the two harness plugs.
If just swapping clusters, install is just the reverse.
If you're interested in maintaining correct mileage, then just swap the speedos. Easy to do, just be careful with the plastic tabs for the bezel parts.
Easiest if done while steering wheel is all the way down.
never heard of the park thing but it would make sense that something odd would come up like that htough. Like RedHot said though, it'll be just a straight swap, and with the tach its always a plus
^ yes, the auto will work with the "P" light on, and when you change it, you might have overhead lighting issues in the cluster, and sometimes when you tamper with the cluster, you might damage other parts, it happened to me and now i'm ordering the gas/temp combo gauge from factory because it went bad
but yeah, the tach is so much better when you get it, i was so glad when i swapped it in my 97 dx
mentaldis0rder
07-29-2006 10:40 PM
1998wagonhatch
08-15-2005 03:36 PM
monty23psk
05-22-2004 06:37 PM
