Reverse i-VTEC on R18A engine. Gen8 must read
Since this topic has not been discussed here that I know of, I thought you allmight like to know thatthe gen8 (2006 and up) R18A motor in the non-SI Civics is a reverse VTEC. The hot cams are the non-VTEC cams and when the VTEC kicks in it is the economy cams.
Here is a link to the article and a quote from it below:
http://asia.vtec.net/Engines/RiVTEC/index.html
So the new SOHC i-VTEC implementation is an entirely new implementation, quite unlike those already in use. Under normal driving conditions, the R18A runs on its normal set of cam-lobes which in a completely reversed role, Honda calls the 'hot-cams'. So VTEC-off on the R18A means it can be considered to be running high cams. When the right conditions are acheived for fuel economy, VTEC engages the 2nd set, the 'low' or 'economy' cams. Thus VTEC-on on the R18A means it is running low cams. More importantly is VTEC engages the low-cams only if the right conditions for fuel economy are acheived. If they are never acheived, like when we are driving aggressively for the whole trip for e.g., VTEC will never open on the R18A
RE: i-VTEC on R18A engine
ORIGINAL: civic_burns_all
so what good does that doo?
After reading through the article several times, I decided to change my style of driving from shifting up at the lowest RPM to using the minimum throttle. I now generally shift up at about 2K+ and make sure I never stomp on the gas pedal. The last tank (70% highway) was a whopping 39.8 MPG (407 miles on 10.23 gals). I shall continue to monitor my gas usage.
One thing I did notice, is that I can now feel the VTEC kick in (out actually)at 3500 RPM, where I couldn't before. The computer obviously remembers I normally use low throttle.
zacky1st
10-06-2008 08:37 PM
