Rookie Question about motor swap
Old 09-21-2009, 05:24 PM
TxFireman1972's Avatar
I have the D15B7 and the 5spd in the 95 2DR I currently have. Would it be the exact same motor and tranny in the 94 model 4DR? I know its a 4cyl amd 5spd. Were there options or would it definitely be the same?
Old 09-21-2009, 09:33 PM
EJ8_Man's Avatar
It should be the exact same engine. Honda produced the same engine for all their DX models from 1992 - 1995 - the trim doesn't matter. If it has a DX sticker on the back, and no one has messed with the motor it will be a D15B7
* Displacement : 1,493 cc (91.1 cu in)
* Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
* Compression : 9.2:1
* Power : 102 hp (76.1 kW, 103 ps) @ 6200 rpm
* Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 3800 rpm
* Valvetrain : SOHC (4 valves per cylinder)
* Cam Gear: 38 Tooth
* Piston Code : PM3
* Fuel Control : OBD-1 MPFI
* ECU Code: P06
And sell the rims like people are saying You have a good deal on your hands. With the right tools the swap should take 1 - 2 days. Should bolt directly into the chassis.
Old 09-21-2009, 09:41 PM
ANY MOTOR FROM A 92-95 CIVIC WILL FIT RIGHT INTO YOUR CAR PERFECTLY WITH NO EXTRA MODS NEEDED. but also you can fit any D" series engine right in from 88-00
with minor work( putting all your stuff onto the new engine).
Old 09-21-2009, 10:26 PM
EJ8_Man's Avatar
Depends on where he lives. I know in California you have use a motor from the same year as your car, or newer. You can probably get away with putting any OBD1 motor in it. But not OBD0
Old 09-21-2009, 10:34 PM
Also, a +1 on those rims. What are on that 4dr are the rims from a 99-00 Civic Si, which is the highest trim level. Very highly sought after by people who are Honda purists and like to have all nice factory accessories. I got mine for $250 with no tires because they had a couple of scuffs and slight curb damage. If those are in near perfect shape, you can probably get $300 for just the rims alone. If they are in good shape AND have good tires, you can easily make enough profit off of them to offset half the cost of that car. Then you can swap over the engine and the steelies off the 2dr and have a parts car for little stuff.
Old 09-22-2009, 06:40 PM
Are the manual trannies the same in 95 and 95? Was there more than one choice on the manual tranny?
Old 09-22-2009, 06:49 PM
hamorhead's Avatar
they will fit the same but the different trim levels have different gear ratios
si/ex=short gears (acceleration)
dx/lx=medium gears
cx/vx= long @$$ gears (gas milage)
Old 09-22-2009, 06:50 PM
all 92,93,94,95 civics are the same generation. now you have different options with the gears on the trans. from the trim of the civic.the dx,lx,vx,ex,si.
dx,lx (d15b7)are your base models and have just a normal trans
ex,si (d16z6)are your sporty, upgraded models and have short gears in the trans
vx,cx (d15z1)is your economy gas saver model and has real long gears.
Old 09-22-2009, 06:53 PM
hamorhead's Avatar
^haha beat you to it
and the cx has the same tranny as the vx fyi
How hard would it be to swap over to an auto?
Quick Reply: Rookie Question about motor swap
