Rough idle when cold!!!! HELP!!!!!!!!!!!!!!!!
Old 07-24-2008, 05:32 AM
SI fanatic's Avatar
Default Rough idle when cold!!!! HELP!!!!!!!!!!!!!!!!
Hi guys.dont knowwhether am in the right forum but i have a lil problem with my civic. whenever i start it and the engine is cold it has a low rough idle, especially in the morning. i would have to give it a lil throttle to stay on. but when it reaches normal operating temperature it stops and the idle is fine. any reason what might be causing this? oh its a 97 hb with a jdm b16a swap BTW. any help would be appreciated thanx!!!!
Old 07-24-2008, 06:16 AM
Default RE: Rough idle when cold!!!! HELP!!!!!!!!!!!!!!!!
Sounds like a problem with the Fast Idle Valve. Try to clean port where air bypasses from the throttle body to intake manifold. If problem persists, do the same with the EACV and also try adjusting the idle screw. The 88-90 Civic manual at the link in my signature may also be helpful.
Old 07-24-2008, 08:12 AM
SI fanatic's Avatar
do u know how much the rpm should be at normal idle?
Old 07-24-2008, 08:22 AM
About 750 rpm - no load
About 810 rpm - high load
whittier97370
08-29-2010 04:41 PM
boostnm3
12-22-2009 01:42 PM
Stumasters
01-20-2008 12:58 PM
96ekhatch
12-30-2007 02:03 PM
brinriha
06-14-2007 10:55 PM
Quick Reply: Rough idle when cold!!!! HELP!!!!!!!!!!!!!!!!
