s2000 Cluster Swap Wiring Guide - HondaCivicForum.com
Reply
Old 01-29-2010, 11:51 AM
supersize's Avatar
Sir Banned-a-lot
Default s2000 Cluster Swap Wiring Guide
Ok here it is. All EG EF EK DC2 gauge swaps.. Ugh, I just spent two hours doing this, hope it's appreciated.
I guess hook up all the power circuits to an ignition power source. Doesn't seem to have a wire for any memory circuit.
AP2 Clusters have a clock, and probably totally different wiring. This is for the 2000-2003 S2k Gauge Clusters
Holding down the SEL button will switch between KM/H and MPH
Pressing the + and - buttons will change the brightness of the cluster.
Connector A ----------------------------------------------- EG harness
EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG EG
1 BLU/RED (Seat belt reminder) --------------------------- BLU/WHT (B10 Seatbelt Light)
4 PNK (SRS) CONNECT TO +12V power (A10 IGNTION POWER) TO TURN OFF LIGHT (or correct wire if you have it)
6 YEL (Fuse 5) ------ONLY IN CANADA-ONLY IN CANADA-------- BLK/YEL (A10 IGNITION Power)
7 GRN/RED (Left turn signal (+)) ------------------------- GRN/BLU (A4 Left Turn) WORKS
8 GRN/YEL (Right turn signal (+))------------------------- GRN/BLU (A3 RightTurn) WORKS
9 RED/WHT (High beam (+)) -------------------------------- RED/GRN (B1 Highbeam) WORKS
If positive trigger high beam Connect A10 to ground, A9 to switch. If trigger to ground, Connect A9 to Power and A10 to switch. Probably situation 1.
10 RED/BLU (High beam (-)) ------------------------------- BLK (B6 Ground)
11 BLU/BLK (Trunk indicator) ----------------------------- GRN (B9 Trunk Open) WORKS
Connector B
2 RED/YEL (Fuse 45) -------------------------------------- BLK/YEL (A10 Power)
OK, B2 doesn't seem to do ANYTHING. I guess hook it up, I'll look for more details tomorrow.
B3 is the switch between bright and dim. I would connect it to (red/black A11 Gauge Lights)
3 RED/BLK (Circuit 11 dash and console lights (+)) ----- +12 dims the cluster, so A11 or A12, someone test and I'll edit this.
4 YEL (Fuse 5) ------------------------------------------- BLK/YEL (A10 IGNITION Power)
5 WHT/RED (Fuse 25) -------------------------------------- BLK/YEL (A10 IGNITION Power)
6 GRN (Door Pin Input ground signal) ------------------ Door Pin Switch I can't Find
8 BLK (Ground) ------------------------------------------- BLK (B6 Ground)
9 BLK (Ground) ------------------------------------------- BLK (B6 Ground)
10 RED (Circuit 12 dash and console lights (-)) -------- BLK (B6 Ground)
Connector C
1 Wht/Blk VSS OUTPUT ------------------------------- Use to connect to regular speedo if ya want. Step down from high pulse rate to regular pulse rate.
3 BLU/WHT (Vehicle speed signal input (-)) --------------- Connect to VSS Converter
5 BLU (RPM signal input) --------------------------------- BLU (A8 Tachometer) Should Work
7 YEL/GRN (Coolant temp input) --------------------------- Connect to ECT Converter
8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (A1 Fuel Gauge) Should Work
15 BLU/YEL (Cruise control indicator (-)) ---------------- Cruise Control I can't find, Probably Red with a Blu stripe.. Maybe B3 Probably dont have cruise control WORKS
Connector D
8 BLU/RED (ABS indicator input) Connect to GROUND to turn off light or correct wire if you have it.
9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (B2 Brake Light) WORKS
11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (A5 Charging Light) WORKS
(both batt and brake lights come on.)
12 BLK/YEL (Fuse 6) -------------------------------------- BLK/YEL (A10 IGNITION Power)
13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (A6 Oil Pressure) WORKS
14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (B5 MIL Lamp) WORKS
16 WHT/RED (Fuse 25) ------------------------------------- BLK/YEL (A10 IGNITION Power)
AND FOR AN EF EDIT 90-91 EF CLUSTER
EF 90-91 EF 90-91 EF 90-91 EF 90-91 EF 90-91 EF 90-91 EF
Connector A ---------------------------------------------- EF 90-91 harness
1 BLU/RED (Seat belt reminder) --------------------------- BLU/RED or YEL/RED (B5 Seatbelt Light)
7 GRN/RED (Left turn signal (+)) ------------------------- GRN/BLU (A1 Left Turn)
8 GRN/YEL (Right turn signal (+))------------------------- GRN/YEL (B8 RightTurn)
9 RED/WHT (High beam (+)) -------------------------------- RED/GRN (A2 Highbeam)
10 RED/BLU (High beam (-)) ------------------------------- BLK (B1 Ground)
11 BLU/BLK (Trunk indicator) ----------------------------- BLU/YEL (A6 Door Open)
Connector B
2 RED/YEL (Fuse 45) -------------------------------------- BLK/YEL (A10 Ignition Power)
B3 is the switch between bright and dim. I would connect it to (red/black A4 Gauge Lights)
3 RED/BLK ------------------------- +12 dims the cluster- RED/BLK A4 Lts On Input
6 GRN (Door Pin Input ground signal) ------------------ BLU-YEL (A6 Door Open) Door Pin Switch
8 BLK (Ground) ------------------------------------------- BLK (B1 Ground)
9 BLK (Ground) ------------------------------------------- BLK (B1 Ground)
10 RED (Circuit 12 dash and console lights (-)) -------- BLK (B1 Ground)
Connector C
5 BLU (RPM signal input) --------------------------------- BLU (A12 Igniter Unit)
8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (B6 Fuel Gauge)
15 BLU/YEL (Cruise control indicator (-)) ---------------- Blu/Blk Other Plug Cruise Control If you have it.
Connector D
9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (A7 Brake Light)
11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (A11 Charging Light)
13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (A8 Oil Pressure)
14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (A9 MIL Lamp)
AND FOR AN EF EDIT 88-89 EF CLUSTER
EF 88-89 EF 88-89 EF 88-89 EF 88-89 EF 88-89 EF 88-89 EF
Connector A ---------------------------------------------- EF 88-89 harness
EF harness. I'm calling the 12 pin connector A and the 8 pin connector B
1 BLU/RED (Seat belt reminder) --------------------------- NOPE Seatbelt Light
4 PNK (SRS) CONNECT TO +12V power BLK/YEL (A9 Ignition Power) TO TURN OFF LIGHT
6 YEL NOPE
9 RED/WHT (High beam (+)) -------------------------------- RED/BLU (B6 Highbeam)
11 BLU/BLK (Trunk indicator) ----------------------------- GRN/BLK (B7 Hatch Light)
Connector B
2 RED/YEL (Fuse 45) -------------------------------------- BLK/YEL (A9 Ignition Power)
B3 is the switch between bright and dim. I would connect it to (RED/BLK A6 Dash Lights)
3 RED/BLK ------------------------- +12 dims the cluster- RED/BLK A6 Lts On Input
4 YEL (Fuse 5) ------------------------------------------- BLK/YEL (A9 Ignition Power)
5 WHT/RED (Fuse 25) -------------------------------------- BLK/YEL (A9 Ignition Power)
6 GRN (Door Pin Input ground signal) ------------------ BLU-YEL (B5 Door Open MAYBE!! TEST) Door Pin Switch
Connector C
5 BLU (RPM signal input) --------------------------------- BLU (A11 Igniter Unit)
8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (A3 Fuel Gauge)
15 BLU/YEL (Cruise control indicator (-)) ---------------- NOPE
Connector D
8 BLU/RED (ABS indicator input) Connect to B1 GROUND to turn off light or correct wire if you have it.
9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (B4 Brake Light)
11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (A10 Charging Light)
12 BLK/YEL (Fuse 6) -------------------------------------- BLK/YEL (A9 Ignition Power)
13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (B2 Oil Pressure)
14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (A5 MIL Lamp)
16 WHT/RED (Fuse 25) ------------------------------------- BLK/YEL (A9 Ignition Power)
AND FOR AN EK
EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK EK
Connector A ---------------------------------------------- EK harness
1 BLU/RED (Seat belt reminder) --------------------------- RED/BLU (A6 Seatbelt Light)
4 PNK (SRS) Connect to SRS wire, I don't know it. Or +12V power to turn off light.
6 YEL (Fuse 5) ------ONLY IN CANADA-ONLY IN CANADA-------- BLK/WHT (A15 IGNITION Power)
7 GRN/RED (Left turn signal (+)) ------------------------- GRN/RED (B7 Left Turn)
8 GRN/YEL (Right turn signal (+))------------------------- GRN/YEL (A4 RightTurn)
9 RED/WHT (High beam (+)) -------------------------------- RED/GRN (B6 Highbeam)
10 RED/BLU (High beam (-)) ------------------------------- BLK (A2 Ground)
11 BLU/BLK (Trunk indicator) ----------------------------- BLU/BLK (A3 Trunk Open)
Connector B
2 RED/YEL (Fuse 45) -------------------------------------- BLK/WHT (A15 IGNITION Power)
B3 is the switch between bright and dim. I would connect it to (red/black B13 Gauge Lights)
3 RED/BLK ------------------------- +12 dims the cluster- RED/BLK B13 Lts On Input
4 YEL (Fuse 5) ------------------------------------------- BLK/WHT (A15 IGNITION Power)
5 WHT/RED (Fuse 25) -------------------------------------- BLK/WHT (A15 IGNITION Power)
6 GRN (Door Pin Input ground signal) ------------------ Door Pin Switch Find wire somewhere
8 BLK (Ground) ------------------------------------------- BLK (A2 Ground)
9 BLK (Ground) ------------------------------------------- BLK (A2 Ground)
10 RED (Circuit 12 dash and console lights (-)) -------- BLK (A2 Ground)
Connector C
5 BLU (RPM signal input) --------------------------------- BLU (B8 Igniter Unit)
8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/BLK (A10 Fuel Gauge)
15 BLU/YEL (Cruise control indicator (-)) ---------------- RED/BLU (E2 Cruise Control)
Connector D
9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (A5 Brake Light)
11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (A16 Charging Light)
12 BLK/YEL (Fuse 6) -------------------------------------- BLK/WHT (A15 IGNITION Power)
13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (B3 Oil Pressure)
16 WHT/RED (Fuse 25) ------------------------------------- BLK/WHT (A15 IGNITION Power)
AND FOR A DC2 94-97 Integra
DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97 DC2 94-97
Connector A ---------------------------------------------- DC2 94-97 harness
1 BLU/RED (Seat belt reminder) --------------------------- RED/BLU (C1 Seatbelt Light)
6 YEL (Fuse 5) ------ONLY IN CANADA-ONLY IN CANADA-------- BLK/YEL (C11 IGNITION Power)
7 GRN/RED (Left turn signal (+)) ------------------------- GRN/BLU (C13 Left Turn)
8 GRN/YEL (Right turn signal (+))------------------------- GRN/YEL (C14 RightTurn)
9 RED/WHT (High beam (+)) -------------------------------- RED/GRN (C15 Highbeam)
10 RED/BLU (High beam (-)) ------------------------------- BLK (D6 Ground)
11 BLU/BLK (Trunk indicator) ----------------------------- GRN (C7 Trunk Open)
Connector B
2 RED/YEL (Fuse 45) -------------------------------------- BLK/YEL (C11 IGNITION Power)
B3 is the switch between bright and dim. I would connect it to (red/black C10 Gauge Lights)
3 RED/BLK ------------------------- +12 dims the cluster- RED/BLK (C10 Lts On Input)
4 YEL (Fuse 5) ------------------------------------------- BLK/YEL (C11 IGNITION Power)
5 WHT/RED (Fuse 25) -------------------------------------- BLK/YEL (C11 IGNITION Power)
6 GRN (Door Pin Input ground signal) ------------------ Lt. GRN/RED (C2 Door Ajar)
8 BLK (Ground) ------------------------------------------- BLK (D6 Ground)
9 BLK (Ground) ------------------------------------------- BLK (D6 Ground)
10 RED (Circuit 12 dash and console lights (-)) -------- BLK (D6 Ground)
Connector C
5 BLU (RPM signal input) --------------------------------- BLU (D13 Igniter Unit)
8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (C3 Fuel Gauge)
15 BLU/YEL (Cruise control indicator (-)) ---------------- RED/BLU (D5 Cruise Control)
Connector D
8 BLU/RED (ABS indicator input) -------------------------- BLU/RED (C8 Abs Light)
9 GRN/WHT (E-brake indicator) ---------------------------- GRN/RED (C16 Brake Light)
11 WHT/BLU (Charging system indicator (-)) --------------- WHT/BLU (D9 Charging Light)
12 BLK/YEL (Fuse 6) -------------------------------------- BLK/YEL (C11 IGNITION Power)
13 YEL/RED (Engine oil pressure switch input (-)) -------- YEL/RED (D11 Oil Pressure)
14 GRN/ORN (Malfunction indicator light (-)) ------------- GRN/ORG (D12 MIL Lamp)
16 WHT/RED (Fuse 25) ------------------------------------- BLK/YEL (C11 IGNITION Power)
AND FOR A DC2 98-01 Integra
DC2 98-01 DC2 98-01 DC2 98-01 DC2 98-01 DC2 98-01 DC2 98-01 DC2 98-01
Connector A ---------------------------------------------- DC2 98-01 harness
1 BLU/RED (Seat belt reminder) --------------------------- RED/BLU (C8 Seatbelt Light)
Connector B
Connector C
8 YEL/BLK (Fuel gauge signal input) ---------------------- YEL/WHT (C1 Fuel Gauge)
Connector D
8 BLU/RED (ABS indicator input) ---- ABS light or connect to ground BLK D6 to turn off light
Courtesy of bigcalidave for writing this
http://www.honda-tech.com/showthread.php?t=1570344
Old 01-29-2010, 06:24 PM
Two hours? To copy and paste?
You guess hook up all the power circuits to an ignition power source? Do you know if this even works?
I once had an AP1 cluster in my hands, ready to put in the car. Tried to wire it using basic information... nothing. It's ALOT harder than it looks... especially to get everything 100% functional such as the speedometer and the ECT gauge.
Old 01-29-2010, 10:00 PM
^lol, I think he copy/pasted what you quoted too
I think rywire.com makes a plug n' play harness (you have to buy VSS signal converter and other converters still though)
Old 01-29-2010, 11:13 PM
danomatic93's Avatar
June 2010 ROTM
I think the speedometer signal converter was called 'speed healer' but I've heard that it's no longer made...
Old 01-30-2010, 02:17 PM
supersize's Avatar
Sir Banned-a-lot
@cvcrcr99: copy and paste lol
@trust: yes there is some kind of harness thing for it, alot of people are doing it on HT now
@danomatic: all you need to do to the vss is convert it from analog to digital, it will take the analog data, convert it to digital and display it
Old 01-30-2010, 03:05 PM
Haha. Right.
Link?
How exactly do you do that?
Anyways, Danomatic.... this is what you are referring to I believe.
http://www.healtech-electronics.com/
-Click on "Speedo-healer" on the left side after the page loads.
Supersize, read my post in the DIY section overhaul thread. I'll gladly quote it and post it here if you want. I didn't post it here originally since I understand you are trying to help out.
Old 01-30-2010, 06:15 PM
supersize's Avatar
Sir Banned-a-lot
this isnt a DIY, thats why it dosent say DIY at the top, it just a guide to tell you what wires go where. Wasnt the idea of the diy overhaul suppost to be copy and paste useful info to bring it to hcf? but whatever, delete all of my DIY's since i dont know anything..
Old 01-30-2010, 06:41 PM
You're still missing the part about letting me know about all these DIYs you're supposedly posting so I can put them on the list.
Old 01-30-2010, 06:58 PM
Many people will tell you that I have defended you at times when it comes to the DIY stuff. I think you making DIY guides on how to chop, lower your car, etc are great. They are great since you know what you are talking about regarding that. I was actually speaking with wellfed and nike about you being able to re-do all the DIY's in the Intro. section that has to do with avatars, pictures, and all that stuff. You're good with that.
DIY, Install Guide, Guide, How To:, are all the same things.
I would never try to come off as a d!ck, especially to members who are active and contribute to help the forum. I appreciate your effort, but try and understand where I am coming from. People see the "guide", feel they can do it, start, realize half way through that the guide isn't complete, and get pissed when no one can help them and leave the site. Sorry if you feel the way you do.
Old 01-30-2010, 11:12 PM
supersize's Avatar
Sir Banned-a-lot
nah i completely understand what your saying, the reason i was posting them was because we were suppost to be adding all these new ones to bring people in, and if they have questions, why would they pm me when they can post it in the topic itself?
questions to me = just me being able to answer
questions on the topic = everyone being able to answer
ya know what i mean? i just dont understand how me posting diy's is going to **** someone off. And how did you defend me on the diy's? i was told my greddy that "my way to help" would be to copy and paste diy's and give credit to the OP's and give a link.. what, people dont want me posting diy's because im suppost to be the post ***** who dont care about the site and just start fights with people? i mean if you dont want me to post technical diy's, i wont, i just diddnt know where it was comming from because on one hand, im being told i can help out the site by posting stuff, and on the other hand, im seeing that diy's shouldnt be posted by people who dont know what their doin.. its whatever tho, next time im ****** around in photoshop, ill make some more diy's
Reply
Thread Thread Starter Forum Replies Last Post
s2000 DASH CLUSTER on 97 civic?? Animal_00 Inside and Out 3 01-08-2013 12:53 PM
engine swap guide? UndrgrndCVX General Civic Talk 0 09-11-2010 05:25 PM
Which s2000 cluster do you like better? inthezoneac Inside and Out 7 08-31-2008 03:51 PM
Engine Swap Parts Guide Chips Engine & Internal 2 05-28-2006 12:26 PM
Tags
98, ap1, ap2, civic, cluster, coolant, ef, ek, gauge, healer, install, s2000, solution, speedo, swap, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
