School me on all of those Civic Motors!
I am shopping for a civic, and I am seeing more non-factory motors than factory ones.
For example,
A 92 CX Hatch has a 1.6 L VTEC(SOHC)...
Not factory i'm guessing.
SI motor? Prelude motor? Del Sol? Many people are distinguishing their motors by a 'B' number such as 'B18' etc... What is the 1.6L SOHC? What 'B' is the DOHC, what 'B' is the non-vtech? School me!
For example,
RE: School me on all of those Civic Motors!
http://www.enginereplacement.com/htd...ngine_spec.htm
That's a good site. It answered alot of similar questions I had.
Thanks,
Heres one I found:
http://www.angelfire.com/extreme4/91civics/engines.htm
Also, WTF is 'JDM'?
I think I will end up buying the 92 CX with the 1.6L SOHC VTEC for my commuter car...
Is there anything to look for when buying a 'swapped' car?
Edit:
http://www.enginereplacement.com/htdocs/chart.htm
This chart shows an 'X' for a D16z in a 92 civic... Chart wrong? Or is this not really a VTEC Motor?
Check out Photo 9... please let me know if 'non-vtec'
I was told to look for the control module under the coil pack, or behind the valve cover.
Heres one I found:
Also, WTF is 'JDM'?
Edit:
I believe JDM stands for Japanese Domestic Market. I can't say for sure whether the chart is wrong, but there are parts/engines in Japan that don't get released anywhere else.
edit:
Sorry...I misunderstood your question regard the 'X'. I'm not sure what the X stands for. Maybe it means that that particular engine and car are totally incompatible.
edit:
Well the easiest way for ME to determine if an engine is SOHC, or DOHC is looking at the letters. D has 1 hump, so it's only has 1 OHC, B has 2 humps so it has 2 OHC.
It's also really easy to determine how many liters an engine has, as it's in it's model name. So for example a B16 is a 1.6 liter, and so is a D16, as for an H22 it is 2.2 liters. Hope that helps you out.
Btw, im not really sure what H stands for, but it is DOHC. Maybe.....Heavy????..because it's about 200 pounds heavier then a stock motor.
ORIGINAL: rallystang
Thx for the replies. I know its SOHC... No questions about that. Just not convinced its VTEC... I guess theres only one sure way to find out!
